23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Details from Cad to Revit
40 Posts No Rating |
I am working a project in revit and want to use some details created in Autocad. is there any way to put these details in a sheet in Revit and make it related to the plan in revit? that is to say from a floor plan created in Revit, make a call out , and this call out would be the detail created in Autocad.
Thanks.
35 Posts No Rating |
What you need to do is-
1/ Create a Drafting View (scale to suit) and import the AutoCAD detail into that (either as a .DWG or a .DXF file) view (View>New>Drafting View)
2/ When you create the section or callout use reference other view and "point" Revit to the detail view you imported.
I hope that helps, have a go it is not that difficult- look in the tutorial section of Revit as this is covered under "Documenting your projects>creating a drafted detail
Good luck!
----------------------------------- AutoCAD & Revit TAFE teacher from regional Australia |
It worked!, Thanks so much.
I love this forum....
9 Posts No Rating |
Great, now How exactly do you "use reference other view and "point" Revit to the detail view you imported." ???
9 Posts No Rating |
OK, just forget it, I found out. It's in the option bar when you create the callout. This day is getting too long...
Old Cad Typical Details |
Mon, May 6, 2013 at 3:27:41 PM
What is the best Method for moving CAD details into Revit Details? |
Fri, Oct 9, 2009 at 9:24:47 AM
Keynoting CAD Details in Revit |
Tue, Jul 24, 2007 at 4:38:14 PM
Auto-Cad Details Into Revit |
Mon, Jun 26, 2006 at 3:34:30 PM
Linked Cad File does not show Cad Xref's |
Fri, Sep 10, 2010 at 10:13:50 AM
