Forums >> Revit Structure >> Technical Support >> Modify bar not updating
Thu, May 23, 2013 at 9:10:28 AM | Modify bar not updating
TeamNga
1 Stars: 1 Votes
Hi all.
Does anyone have an idea why my modify panel is not updating?
When selecting an element, the modify panel updates to offer options for the element you have selected. Example with a truss you get edit profil, reset profile, ect... When placing a beam you get load family, tag on placement, ect...
When I select an element I get the last options used. I have to do a cycle through all the tabs, panel titles, and back to panel bottons for it to update. So if I place a beam, cycle through all I get the correct modify options. I then select a truss and I get the place a beam modify options. I have to do another cycle through all to get the correct modify options. And so forth and so on.
Anyone know what is happening to me?
Tanks.
Thu, May 23, 2013 at 2:14:43 PM | Modify bar not updating
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Have you downloaded the latest service packs?  Also under the "R" pulldown>Options>User Interface there is a section called Tab Switching Behavior where you can choose what you want the tabs to do after clearing a selection of after exiting.
Thu, May 23, 2013 at 2:37:14 PM | Modify bar not updating
TeamNga
1 Stars: 1 Votes
Hey teafoe5.
I dont have the service packs installed. And I checked in to the user interface but everything is the same as my coworkers. We have more than one liscence here and I am the only one that has problems. And with both Rvit Structure and Architecture. So I am thinking more along the line of a windows update meaby. I have had problems with those in the past.
If someone has a solution for me feel free to let me know.
Thanks everyone.
Thu, May 23, 2013 at 2:58:16 PM | Modify bar not updating
Everything is the same ???? Including your equipment?
Install the service packs.
Thu, May 23, 2013 at 3:46:08 PM | Modify bar not updating
TeamNga
1 Stars: 1 Votes
Yes WWHub. Everything teafoe5 has mentionned is the same. Neither one of us has service packs installed and the options, user interface Tab switching behavior are all the same.
I found the problem and it has nothing to do with service packs.
The Ribbon behavoir problem was due to a .net 4.5 installation. I installed Visual C# 2010 Express and it caused Revit to have problems. I found a hotfix to solve the problem. By replacing the AdWindows.dll file in Revit's Program folder the problem was resolved.
Here is the link for the hotfix if this happens to anyone else.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21344242&linkID=9273944
Mon, Aug 11, 2014 at 10:18:43 AM | Modify bar not updating
meridian
i am having the same problems, can someone explain what i have to do to fix this?
i tried clicking on that link but it doesnt work
Mon, Aug 11, 2014 at 10:27:37 AM | Modify bar not updating
We can't help you because you don't tell us what Revit and what updates you have installed.  Also if you installed later versions than the one you are using.
Mon, Aug 11, 2014 at 10:42:34 AM | Modify bar not updating
meridian
im running revit 2013 and i dont recall ever installing any service packs
Mon, Aug 11, 2014 at 10:56:38 AM | Modify bar not updating
TeamNga
1 Stars: 1 Votes
Hi meridian.
Sorry if the link is no longer available. My problem was resolved by replacing the AdWindows.dll file in Revit. (C:\Program Files\Autodesk\Revit Structure 2012\Program). I got the new file from the link though.
But I had the same thing happen again in Revit 2014. With the link no longer available I asked around and was told by a friend to try looking in the ObjectARX folder for that file. CryingC:\ObjectARX 2013\inc). And there it was. I copied it and then copied and replaced it here. (C:\Program Files\Autodesk\Revit 2014).
I dont know if this will work for you also but dont forget that if you try this out, COPY THE OLD FILE TO A SAFE LOCATION FIRST. So if it doesnt work you can put the old one back in.
Hope this helps.
Mon, Aug 11, 2014 at 11:11:22 AM | Modify bar not updating
meridian
I did a search and i dont have a ObjectARX file or folder on my computer so it doesnt seem to work
Mon, Aug 11, 2014 at 11:13:35 AM | Modify bar not updating
#11
2013 has 3 updates.  Install them.
Mon, Aug 11, 2014 at 11:18:12 AM | Modify bar not updating
#12
meridian
this may be a dumb question but where do i get these updates??
i have a revit subscription and they should be emailed to me but i guess im not recieving them
Mon, Aug 11, 2014 at 11:29:46 AM | Modify bar not updating
#13
We too are on subscription and we have never been emailed an update.   This is your responsibility.  Login to the autodesk site and look there.  That is where they are.
Mon, Aug 11, 2014 at 12:24:38 PM | Modify bar not updating
#14
TeamNga
1 Stars: 1 Votes
Hey meridian.
If all else fails let me know and I will e-mail you what I have.
Tue, Aug 12, 2014 at 9:45:39 AM | Modify bar not updating
#15
meridian
i did all 3 updates for revit 2013 and for now it has fixed the issue
thanks
The Modify bar that appears when you click on some element is missing
Sun, Nov 11, 2012 at 7:39:05 AM
Need help to modify rebar bar size!!!!!
Thu, Apr 6, 2017 at 3:03:05 AM
How to modify/ customise title bar on sheet?
Fri, Aug 19, 2011 at 6:56:53 AM
updating model
Mon, Aug 5, 2013 at 8:59:53 AM
Arched LH series bar joist
Mon, Nov 2, 2009 at 7:44:38 AM
Page generation time: 0.1618
