Forums >> Revit Systems >> Technical Support >> How to place receptacles per NEC
Thu, May 23, 2013 at 8:38:59 AM | How to place receptacles per NEC
MsTee
I am doing my first residential project in REVIT.  How do I layout receptacles along the wall to meet NEC 6ft and 12ft spacing requirement without placing dimensions alont the walls first?
Thu, May 23, 2013 at 8:40:19 AM | How to place receptacles per NEC
Almost all elements in Revit show temporary dimensions when you place elements and you can edit that dimension.
Thu, May 23, 2013 at 8:59:15 AM | How to place receptacles per NEC
MsTee
That's fine on a straight surface.  But what happens when the 12' turns a corner?  in AutoCAD you could draw a p-line and measure it.  Or draw a line and off-set the line and rotage it at the corner of the room.  How do I do that in Revit?
Thu, May 23, 2013 at 9:13:51 AM | How to place receptacles per NEC
The same way....
electrical receptacles
Mon, Jul 21, 2014 at 12:17:05 PM
How to Wire Multi-Circuit Receptacles Within 1 Conduit?
Mon, Mar 21, 2011 at 1:19:06 PM
Receptacles not showing in section
Fri, Jun 24, 2011 at 9:01:34 AM
Receptacles cut-off when plotted but not in plan view, why???????????????
Fri, Sep 26, 2008 at 8:49:30 AM
Family Question.
Mon, Aug 1, 2011 at 9:19:10 AM
Page generation time: 1.6756
