Forums >> Revit Systems >> Technical Support >> Editting a mesh in Revit, is it possible?
Thu, May 23, 2013 at 8:08:15 AM | Editting a mesh in Revit, is it possible?
mrnavi
I have a mesh made in rhino, whats the best way to get it into revit so it is editable. for example the mesh would be topography and if i want to cutout a piece of that topography so a building can sit in it. is that possible? if so how?
Any help would me much appreciated! Thanks
Thu, May 23, 2013 at 8:27:13 AM | Editting a mesh in Revit, is it possible?
You can't edit that in Revit.  Make a Revit topography.  Find a way to get a points file and use that.
Thu, May 23, 2013 at 9:03:35 AM | Editting a mesh in Revit, is it possible?
mrnavi
What about in archicad? What if i turn the mesh into a solid (nurbs)? how would that work?
Thu, May 23, 2013 at 9:08:24 AM | Editting a mesh in Revit, is it possible?
coreed
coreed Avatar
4 Stars: 16 Votes
Can Rhino export to dwg? If it can, you can then import that into Revit and make topo.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, May 23, 2013 at 9:13:50 AM | Editting a mesh in Revit, is it possible?
mrnavi
Yes rhino can. Could you please explain to me in detail how its done once ive exported it in dwg. thankyou
Thu, May 23, 2013 at 11:41:22 AM | Editting a mesh in Revit, is it possible?
coreed
coreed Avatar
4 Stars: 16 Votes
Check your Help and Youtube there is tons of info on this:
http://www.youtube.com/watch?v=_K1zvaiymn4
Edited on: Thu, May 23, 2013 at 11:41:50 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, May 23, 2013 at 7:42:42 PM | Editting a mesh in Revit, is it possible?
mrnavi
thanks coreed. it worked perfectly like that. cheers
Importing a 3D mesh model into Revit and creating the mesh to solids
Thu, Dec 15, 2016 at 9:20:20 AM
Wire Mesh Handrail
Mon, Dec 20, 2010 at 3:58:42 PM
Wire mesh curtain wall door for wire mesh wall
Mon, Sep 17, 2012 at 2:57:36 PM
Mesh not rendering to scale???
Mon, Feb 15, 2010 at 12:43:01 PM
3d mesh
Thu, Feb 16, 2006 at 9:01:11 AM
Page generation time: 1.4293
