Forums >> General Discussion >> Revit Project Management >> Autocad details with hatch showing as black/solid
Wed, May 22, 2013 at 11:43:32 AM | Autocad details with hatch showing as black/solid
Chunkymonkey
5 Stars: 3 Votes
Greetings,
I am trying to get some autocad floor details (drawn at 1:1) into my Revit 2013 Arch project. However when linked/imported (doesn't matter which) I still get the same problem, that the autocad hatches are showing as black/solid.
I have looked about the forums for answers, one option is to link/import the details in an oversized scale and then scaled them back down to 1:1 again, this appears to work for some people but I still get the same problem.
Any help would be appreciated.
Many thanks,
CM.
Wed, May 22, 2013 at 11:47:29 AM | Autocad details with hatch showing as black/solid
Your hatch pattern is too intense.  Use a different pattern.  Just because you can see the pattern when zoomed in doesn't mean it is a good pattern.  When we hand drafted, people knew better.
Imported Details from AutoCAD coming into Revit Black Out!?
Fri, Aug 10, 2007 at 1:04:51 PM
Solid Fill Hatch
Sun, Apr 1, 2007 at 8:56:31 PM
Showing column cut on top of wall cut pattern
Tue, May 28, 2013 at 4:06:05 AM
Importing a CAD site plan w/ hatch
Tue, Aug 30, 2011 at 1:51:06 AM
Custom Hatch Patterns
Thu, Dec 23, 2004 at 3:00:32 PM
Page generation time: 0.4846
