16 Users Online (15 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Radial array in Families
Wed, May 22, 2013 at 6:21:31 AM | Radial array in Families
String90
Hi,
have a query,
want to do a radial array of connection points up a curved column, similar to Jean-Marie Cultural centre.
The radial dimension of the column changes as it grows in height, therfore I need the array radial dimension to change with it to keep it parametric. Using a reporting parameter won't work and I cannot do a formula, which i have one, to calculate the radial dimension based on the height and width of the column as it needs to use the reporting parameter and wont let me.
Any help will be appreciated.
I am using Revit 2013.
I can put up the file if anyone wants to have a look at it but am not at my computer right now, so let me know if it will help.
Chris
Thu, May 23, 2013 at 2:20:13 AM | Radial array in Families
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
in that case,i think reporting parameters won't be nessesary.
reporting parameter is for the case when parameter would be get automatically, like pattern panels.. or adpative families..
i can review your file if you upload it.
Edited on: Thu, May 23, 2013 at 2:20:32 AM
want more?
You can get more tips at Enjoy Revit
Sun, May 26, 2013 at 5:22:16 PM | Radial array in Families
String90
Hi sorry for the late reply,
I've attached the file, the view that works best is the left elevation.
I also made a quick extrusion to try and array,
Good Luck!
Thanks heaps.
Sun, May 26, 2013 at 5:27:23 PM | Radial array in Families
String90
Here is the file again, I purged it to make it a little smaller.
Sun, May 26, 2013 at 8:01:03 PM | String90
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Quoting String90 from 2013-05-26 17:27:23
i got the file but can't understand what's the goal u want.
can you explain what you want to make parametric or show me any refernce images?
it seems like Jean-Marie Cultural centre column but a little different. ones at Jean-Marie Cultural centre has all same radius just defferent length(height), but yours changes radius depend on changing heights.
and if you want to use it for column, it's better to placed at the center of left&right ref. plan.
Edited on: Sun, May 26, 2013 at 8:08:37 PM
Edited on: Sun, May 26, 2013 at 8:11:40 PM
want more?
Mon, May 27, 2013 at 5:50:47 AM | Radial array in Families
String90
I want the number of connections  to change as the number of levels change, the fact that the radial dimension changes when the height changes is the problem im having as I want the array radial dimension to change.
Make sense? I know its confusing.
Chris
Mon, May 27, 2013 at 6:49:09 AM | String90
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Quoting String90 from 2013-05-27 05:50:47
Chris
It's really confusing...if i had to make curved and arraied and parametric column, i'd rather use mass and pattern..
I'm sure i can make your goal if i understand clearly..but i think i don't yet..
Can you show me any hand drawings or somwthing?
want more?
Tue, May 28, 2013 at 3:04:01 AM | Radial array in Families
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
i made a family just for reference.
hope it helps you.
it will show how arch can be controled with parameters.
want more?
Radial Array in a Family
Mon, Apr 11, 2005 at 8:56:12 PM
Radial array in families
Thu, Nov 25, 2004 at 4:30:59 AM
Change start and end heights of elements in radial array
Tue, Sep 20, 2016 at 7:06:49 AM
Parametric Radial Array
Wed, Dec 14, 2011 at 1:39:23 AM
Radial Array in Elevation View
Sat, May 29, 2010 at 9:20:46 PM
Page generation time: 4.7043
