Forums >> Revit Building >> Technical Support >> Need Help with Revit Arch. 2013
Tue, May 21, 2013 at 10:04:24 PM | Need Help with Revit Arch. 2013
rojo09
So i just loaded Revit arch and structural 2013 to my lap top
everything is ok till i opened it and started to try to due a project for work and i have no walls, doors, windows, columns
i click wall and in my properties i only have Basic Wall Wall 1 only
i tryed loading families but i cant seem to open them on my project or have them there permanently when i open a new project
i hope im making sense but its been a long day tryingt to figure it out.
if you could post or email me that will be great lrojo09@yahoo.com
Thanks.
Wed, May 22, 2013 at 7:24:04 AM | Need Help with Revit Arch. 2013
Walls are a system family.  Create your own types by duplicating the type you have and defining new.
Doors, windows and columns can all be loaded from your library.
If you want to do architectural elements, make sure under the Revit R / Options tat you have the right tools loaded.  See attached.
Wed, May 22, 2013 at 9:16:37 AM | Need Help with Revit Arch. 2013
rojo09
i dont even have that tools and analases bar
Wed, May 22, 2013 at 9:20:39 AM | Need Help with Revit Arch. 2013
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"i dont even have that tools and analases bar"
You don't have what tool?  Do you know how to create a new wall type?  All you do is click wall, then on your properties bar click edit type, then duplicate the type, name it whatever you want and under there click structure and make whatever type you want.
Wed, May 22, 2013 at 9:20:41 AM | Need Help with Revit Arch. 2013
Click on the revit R in the upper left corner & pulldown to options then pick user interface.
Wed, May 22, 2013 at 9:32:49 AM | Need Help with Revit Arch. 2013
rojo09
User Menuteafoe5 even when i click wall theres only one that coms up Basic wall wall 1 no brick wall no Mstd wall interior wall
only thing i have is
active theme
keyboard shortrcuts
tooltip assistance
and the tab switching behavior
Wed, May 22, 2013 at 10:00:05 AM | Need Help with Revit Arch. 2013
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Can you post a screen shot of what your view looks like after you pick the wall command? It sounds like something is wrong with your install if that is all you have for your options.  Is the software really from Autodesk?
Wed, May 22, 2013 at 10:17:50 AM | Need Help with Revit Arch. 2013
rojo09
im trying to post a pic il wont let me either
revit arch 2013 my 3d views are transparent???..
Mon, Mar 25, 2013 at 7:45:25 PM
Charts - Revit Arch. 2013
Mon, Sep 30, 2013 at 8:54:47 AM
Missing Icons in Revit Arch 2013
Wed, Jun 5, 2013 at 7:34:40 AM
Revit Arch. 2013 - Material Take-offs on specific areas
Thu, Mar 7, 2013 at 8:23:26 AM
Revit Arch 2013 - Roof - Starts at first floor level and second floor level
Mon, Sep 10, 2012 at 8:11:53 AM
Page generation time: 1.4326
