Forums >> Revit Building >> Technical Support >> fill pattern in wall
Sun, Feb 5, 2006 at 12:05:52 PM | fill pattern in wall
carlosgt
I am putting together a set of construction documents for a residence, Everything looks fine, but in my floor plan I am showing a fill pattern (or hatch) for the walls, which is fine, but I do not need show this pattern in my foundation plan, I tried to go to the visibility-walls and turn this property off , but I can not find it, It only shows me surface pattern and others properties. Another issue is that in the exterior masonry walls we use a symbol for the fill cells, which is little square, that should be shown only in floor and foundation plans. For now I just draw the square in the respective locations in the floor plan, and copy them to the foundation plan. Is there any way to create some kind of "layer" or family (like we do in Autocad) and turn it off or on whenever we want? I appreciate your suggestions and ideas. Thanks.
Sun, Feb 5, 2006 at 5:16:35 PM | RE: fill pattern in wall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
1. Use you detail levels to control this. In your foundation plan use the coarse scale detail level. All walls have a separate parameter for assigning a cut pattern at coarse detail level. 2. Pick a family category your not using, create a family for the fill cells and place them as necessary then turn off that family category in the views you do not wish to display. Or if you're using worksets place them in a workset that is turned off in the views you don't want it in. HTH.
Wall Fill Pattern question
Tue, Oct 23, 2012 at 8:39:37 AM
Scaling fill pattern
Thu, Nov 17, 2011 at 4:01:24 PM
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:36 AM
EDITTING FILL PATTERNS
Fri, Dec 9, 2005 at 6:51:29 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Page generation time: 2.2541
