Forums >> Revit Building >> Technical Support >> Sketchup model becoming an adaptive component
Mon, May 20, 2013 at 12:31:42 AM | Sketchup model becoming an adaptive component
espino05
I have attached my sketchup file. My question is which is the best/easiest way to draw this in Revit. Or would it be easier
importing the Sketchup file into Revit. Thanks
Mon, May 20, 2013 at 7:26:49 AM | Sketchup model becoming an adaptive component
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What is it?  It looks pretty simple, I would most likely create the family in Revit unless it has a complex application.
Mon, May 20, 2013 at 9:02:04 PM | Sketchup model becoming an adaptive component
espino05
Thats the problem, Im not to familiar with families.
Tue, May 21, 2013 at 8:02:11 AM | Sketchup model becoming an adaptive component
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
This is a good source to start with for learning family creation.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13376394
Can really help you further without more information on what it is and what it does
Adaptive component documentation
Wed, May 11, 2011 at 3:51:41 AM
Show user created dimensions within Adaptive Component in Sheets (2016)
Fri, Jul 1, 2016 at 1:55:50 PM
Adaptive component - Bracket
Mon, Oct 12, 2015 at 6:11:04 PM
Adaptive component Problem
Fri, Oct 19, 2012 at 5:39:19 PM
Adaptive Component - Flaky Arc
Tue, Feb 9, 2016 at 1:26:48 PM
Page generation time: 0.4564
