Forums >> Revit Building >> Technical Support >> Stair
Sun, May 19, 2013 at 10:02:24 PM | Stair
annateo301
I am currently working on an As-built project which has a stair with the first tread that curves around.. Currently, I am using filled region to show it in floor plan. However, I'd like to know if Revit can do such stairs.
ps: I've included a screeshot of what I did.
Thanks!
Mon, May 20, 2013 at 6:06:30 AM | Stair
coreed
coreed Avatar
4 Stars: 16 Votes
You would create that first tread seperately from the rest of the stair.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, May 20, 2013 at 7:54:21 AM | Stair
No need to sketch it seperately.  Just pull the boundry line bak to the second riser and add your riser line arc.  See attached.
Mon, May 20, 2013 at 10:37:14 AM | WWHub
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting WWHub from 2013-05-20 07:54:21
WWHub, what you show is not what's shown in the sketch. He wants to go back one more thread
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, May 20, 2013 at 11:17:34 AM | Stair
Missed that ....
but basically still the same except the riser has to return along the stringer as I have done in the attached.
Mon, May 20, 2013 at 2:07:46 PM | Stair
coreed
coreed Avatar
4 Stars: 16 Votes
o.k., that works.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, May 20, 2013 at 11:25:24 PM | Stair
annateo301
Oh wow! That's not as complicated as I thought it would be..
Cheers!
Can not swap out one stair family for another
Thu, Sep 19, 2013 at 12:24:19 PM
How can I create a split stair without multiple and separate stair components?
Tue, Jan 5, 2016 at 5:32:53 AM
Stair Nosing
Fri, Dec 2, 2016 at 2:01:57 PM
Simple Stair Nosing error
Thu, Mar 5, 2015 at 9:15:24 PM
Stair Showing Below Mezz Slab
Fri, Jan 27, 2012 at 8:21:10 AM
Page generation time: 0.0701
