15 Users Online (13 Members):
Forums >> Revit Building >> Tips & Tricks >> If you are having cloud rendering issues "Bug"
4 Posts No Rating |
I just found out that any views whose name contains paranthesis/ comas (not sure which one) do not get send to the cloud, it gets stuck in the window where you enter your rendering settings... i looked around the web for a solution but could not find it... dont ask me how i figured it out...
I rendered a view named (3D VIEW) in the cloud with 2013 and it worked just fine. What version of Revit are you using?
4 Posts No Rating |
Try a coma, I had both parenthesis and coma no sure which one caused the problem... I was using Revit 2013. I tried rendering different views and all the ones that contained comas or parenthesis would not render, the other would go though... as soon as I changed the name they worked...
Yes it appears that if you have a comma in the view name it will not render in the cloud. The parenthesis are fine to use however. This should be reported to Autodesk.
To be honest I'm not sure why you would use a comma in a view name anyway.
4 Posts No Rating |
Well not a necessity to have a coma, just my style to keep things organized, since it allowed me to use them why not... just trowing it out there in case anyone experiences this issue!!!!!!!!
image when "render in cloud" black |
Tue, Jan 14, 2014 at 8:51:32 AM
Rendering in cloud |
Fri, Jan 6, 2017 at 7:34:57 PM
Revit 2009 Rendering Issues [ 1 2 ] |
Sun, Sep 6, 2009 at 10:37:19 AM
15
"The Rendering library is not installed. Rendering features will be disabled" |
Tue, Mar 5, 2013 at 1:40:18 PM
Ortho issues..."SO" not working? |
Mon, Jul 9, 2012 at 6:52:13 AM
