Forums >> Revit Building >> Technical Support >> Poche Not Printing?
Fri, May 17, 2013 at 2:11:21 PM | Poche Not Printing?
palladio1234
5 Stars: 3 Votes
I have a plywood poche that will not print now that we are using revit 2014.  Whats weird is that when I zoom into the detail and print it as fit to page and visible portion of screen it shows up correctly.  When I zoom back out and print the whole 24"x36" sized sheet at zoom 100% the poche is not visible and only shows a solid white fill.  I tried printing to a PDF and it has the same problem.
Anyone else having poche printing problems now using revit 2014?
Thu, May 30, 2013 at 11:32:36 AM | Poche Not Printing?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The scale of you filled region is most likely to small so what you are zoomed to 100% it is not showing.
Thu, May 30, 2013 at 1:00:45 PM | Poche Not Printing?
palladio1234
5 Stars: 3 Votes
Thank you for the response.
Whats weird is that it had always printed correctly until I upgraded to Revit 2014.  Now it won't print anymore : /  It just shows as a solid white filled region.  When I zoom in to it it shows up correctly.  When I increase the scale of the drawing it prints correctly.  I dont know why the upgrade from 2013 to 2014 would downgrade drawing resolutions...
I am hoping a patch will fix it in time.
Tue, Sep 10, 2013 at 9:51:44 AM | Poche Not Printing?
palladio1234
5 Stars: 3 Votes
anyone else have a suggestion?
Tue, Sep 10, 2013 at 10:08:03 AM | Poche Not Printing?
Quite often, people just remember incorrectly.  If you want to verify the problem, create a new file in your 2013 program and use that pattern at the same view scale and verify that it prints.  Then if it really does, upgrade that file and see if it still prints.  If it does, then something happened with your conversion.  If it doesn't, the you need to do one more thing.  Create a new file with a view of the same scale and fill pattern and print that.  If that prints, then you should tell autodesk that they have a conversion problem (and you can replace the pattern in your file).  If it doesn't print, then tell them that.
Tue, Sep 10, 2013 at 10:11:37 AM | Poche Not Printing?
palladio1234
5 Stars: 3 Votes
Thank you I will try this today and see what happens.
revit 2016 poche
Wed, Sep 23, 2015 at 2:50:33 PM
Wall Poche and Phasing....
Wed, May 31, 2017 at 8:40:33 AM
Underlayer Leaves Ghosting in Poche
Fri, Mar 13, 2015 at 7:49:29 PM
poche walls
Wed, Jul 25, 2007 at 1:26:04 PM
Walls, Floors and Roofs to show hatch pattern AND color poche?
Sun, Apr 29, 2012 at 12:24:19 PM
Page generation time: 2.9581
