Forums >> General Discussion >> Revit Project Management >> Element is Not Supported
Fri, May 17, 2013 at 12:15:04 PM | Element is Not Supported
Tmallak
whenever i try to model even the slightest thing which is a beam supported by two columns revit says it's not supportedbut no errors appear whne the analytical links are not activatedand if they arent the analytical beam is not straight :S :S Sad Help please ?
Fri, May 17, 2013 at 12:17:40 PM | Element is Not Supported
Tmallak
3 views so far and no replies !!!i really could use some help
multiple instances of the same view in sheet not supported
Tue, Dec 4, 2012 at 12:40:35 PM
Deleting an element within 3D environment doesn't delete the element from the 2D
Tue, Jun 26, 2012 at 1:35:59 PM
switching element type to curtain element error
Wed, Nov 16, 2011 at 1:37:03 PM
Keeping an Element Keynote from changing?
Mon, Apr 15, 2013 at 12:14:43 PM
Creating an element that only appears in one view
Fri, Feb 7, 2014 at 8:31:38 AM
Page generation time: 0.0991
