Forums >> Revit Systems >> Technical Support >> Problem with a rectangular section on an adaptive arch
Fri, May 17, 2013 at 11:39:57 AM | Problem with a rectangular section on an adaptive arch
magiay
When I put a adaptive arch on a model the section is twisting, especially when I put it on the south side (picture). The orientation of the adaptive points is orthogonal on placement. Anyway, I tried every orientation for the adaptive points but in every cases the section was twisted or bended. What do I did wrong?
Fri, May 31, 2013 at 12:38:11 AM | Problem with a rectangular section on an adaptive arch
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
making arch with 2 points is very tricky.. direction of the shape in sweep is hard to control in this case.(it rotated depends on the location of adoptive points)
i recommand make 3 or more points in conceptual mass for placing adaptive family and also in adaptive family.(dont make arch in adaptive family..)
want more?
You can get more tips at Enjoy Revit
Mon, Jul 15, 2013 at 10:03:49 PM | Problem with a rectangular section on an adaptive arch
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
i just found what was wrong..
delete two profiles at the middle, and check family parameter 'always vertical)
see attatched images
hope not too late.
Edited on: Mon, Jul 15, 2013 at 10:04:45 PM
want more?
Tue, Jul 16, 2013 at 8:50:32 AM | Problem with a rectangular section on an adaptive arch
magiay
I solve that problem in other way at that time (I just create some beams in the main project who are following a curve), but still... that was something that put me wonder, so...thank you for the solution!
Tue, Jul 16, 2013 at 7:21:17 PM | magiay
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Quoting magiay from 2013-07-16 08:50:32
thank YOU :-)
i got better understanding about adaptive components because of your question.
want more?
Problem with a rectangular section on a adaptive arch
Sun, May 19, 2013 at 2:05:22 AM
Section box which is not rectangular
Mon, Jun 24, 2013 at 8:15:54 PM
Simple Rectangular Toposurface Dividing Automatically... (Revit Arch 2014)
Wed, Jun 4, 2014 at 11:10:06 AM
11
Adaptive rectangular pattern with bubbly holes
Thu, Sep 12, 2013 at 6:31:28 AM
adaptive components
Fri, Jan 23, 2015 at 7:12:31 AM
Page generation time: 0.8533
