Forums >> Revit Structure >> Technical Support >> Revit Structure 2013 windows 7 & windows XP Compatibility
Wed, May 15, 2013 at 11:58:10 AM | Revit Structure 2013 windows 7 & windows XP Compatibility
RevitTyro
Can anyone help me out it
This situation:
A central model file was created in a Revit structure 2013 x86 (windows xp). other Users with Revit structure 2013 x64 (windows 7) need to access & modify the central file but it only opens but could not save or take ownership of any workset.
Is there a fix or an updated for this?
Wed, May 15, 2013 at 1:09:47 PM | Revit Structure 2013 windows 7 & windows XP Compatibility
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You should rarely take ownership of an entire workset.  Are you getting any errors?  Are you sure its a central file?  If its a central file and someone owns all of the worksets you need them to sync and release the worksets.
Wed, May 15, 2013 at 1:27:10 PM | Revit Structure 2013 windows 7 & windows XP Compatibility
You should not be editing the central anyway, always open with create a local checked.
And as tefoe says... Is it really a central file?
Windows 10
Fri, Aug 7, 2015 at 10:11:53 AM
Revit 2010 compatibility with Windows 8
Thu, Dec 6, 2012 at 6:24:09 AM
Release Compatibility Structure - Architecture - Etc?
Tue, May 17, 2011 at 1:57:25 PM
painting split walls with windows
Thu, Nov 15, 2012 at 3:17:04 PM
Revit Architecture 2012 Compatibilty with Windows 10
Thu, Feb 14, 2019 at 4:59:13 AM
Page generation time: 4.2774
