Forums >> Revit Building >> Technical Support >> wall joins
Tue, May 14, 2013 at 1:36:19 PM | wall joins
Hi,
Is it able to join 2 walls like this? -> see attachment .jpg please.I'm asking, because I can't do this in Revit. So I made it in pshop for showing an example.
I would appreciate if someone could help me.
THanks,
Tue, May 14, 2013 at 1:47:07 PM | wall joins
EDIT: attachment 1 is not correct. watch attachment 2.jpg pls.
Tue, May 14, 2013 at 1:53:43 PM | wall joins
Assuming the grey is the core, you will always get # 3 in a joined condition.  But if you have wrapping on and turn off the wall join on the blue butten at the end of the wall, you should get #1.
Tue, May 14, 2013 at 3:01:49 PM | wall joins
Hi,
It's not possible to unjoin these 2 walls. I did attach the .rvt file (revit 2013).
they are still joined, wrap is on and the grey one is idd the core.
Tue, May 14, 2013 at 3:15:08 PM | wall joins
You are incorrect, you did not do what I told you to do.
I wrote"...turn off the wall join on the blue butten at the end of the wall."   Click on the wall then right click on the blue butten at the end of the wall.  Then click on "disallow join".
Tue, May 14, 2013 at 3:18:32 PM | wall joins
Smile you are genious. thank you very much. you did help me a lot with this!
Tue, May 14, 2013 at 3:24:52 PM | wall joins
thank you, but actually it didn't work yet. I thought it was correct, but it did something else then it should be like the left image in my attachment....
I did select the brickwall > right mouse click on blue dot > disallow join > moved the end of the wall to the correct place and now I got this -->> see new attachment. Did I read it well for this time?
I tried to play with it afterwards, but didn't help yet...
Tue, May 14, 2013 at 3:26:50 PM | wall joins
Not a genius - just doing this for awhile.
Revit has a lot of nuances .... if you really want to learn it, READ THE HELP!  Just start on a category and read everything in that area.  It may make little sense at first but by experimenting with the processes shown, it will all soon come together.
READ THE HELP!
READ THE HELP!
READ THE HELP!  I really can't say it enough.....Like Ragu, it's in there.  (If you are American, you understand this)
Tue, May 14, 2013 at 3:34:48 PM | wall joins
1045642112
I did read the help and I will keep reading it. I just didn't find it yet there!
If you think that READING HELP is the solution, send RevitCity a mail and tell them to quit this job, because people are asking questions here. Maybe they will listen and close the website. Why? Because Revit has HELP!
Does anyone else wish that there was a toggle to make wall joins the default off
Wed, Aug 19, 2009 at 9:49:42 AM
Can you make wall joins Miter by Default?
Wed, Dec 21, 2016 at 1:52:44 PM
14
Wall joins in linked files
Mon, Aug 19, 2013 at 2:58:42 PM
I hate the Revit Automatic Wall joins
Thu, Oct 25, 2007 at 9:59:44 AM
wall joins
Thu, Oct 20, 2011 at 4:37:14 PM
Page generation time: 0.5640
