Forums >> Revit Building >> Technical Support >> core boundaries
Tue, May 14, 2013 at 10:09:35 AM | core boundaries
Hi all,After searching via google I couldn't find an answer: What are core boundaries, why I can't delete them and why should I use them? (look attachment screenshot)Maybe a stupid question, but there are always people that say: "stupid questions don't exist"  Now I've got backup! Could someone explain this or solve the problem?
Thanks in advance...Sef. (Revit architecture 2013)
Tue, May 14, 2013 at 10:27:10 AM | core boundaries
Why Google when you have an excellant HELP?  << Read about walls and what the layers are in your HELP.
Tue, May 14, 2013 at 10:44:13 AM | core boundaries
Hi,
Thanks for your reply, but I couldn't find any information about it in HELP. Also my search function didn't work... I don't know why, but I can't search. That's the reason I'm asking it here : )
I'm still searching, but please, if someone knows, tell me. I have to know!
ty,
Sef
Tue, May 14, 2013 at 11:02:31 AM | core boundaries
If you can't use your HELP then get that fixed before going any furthur.  Here are the topics you should read.
Tue, May 14, 2013 at 12:01:37 PM | core boundaries
for some reason I did post twice the same.. or the server.. ok.
thank you! I'm going to read that.
Tue, May 14, 2013 at 12:15:51 PM | core boundaries
For HELP I'm using http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0328-Build_th328/0330-Architec330/0331-Walls331/0336-Modifyin336/0347-Working_347/0354-Layer_As354
now.
I'd read it, but still don't have any answers on my questions yet.... Those are rules, they don't explain me what core boundaries are...
Thank you anyway.
Tue, May 14, 2013 at 1:06:47 PM | core boundaries
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Every wall type in Revit has a core material with a boundary on either side of it. The core which is the layers between the two boundary lines defines the structural part of the wall and influences the behavior of the wall and how it interacts with other elemenets in the model.  The core of a wall creates references to which you can dimension. The core boundary cal also be used as the location definition when drawing host elements like walls, floors, ceilings and roofs.
Tue, May 14, 2013 at 1:31:59 PM | core boundaries
You are awsome Smile Thank you, that was clear!
I figured out a little bit its behaviour.
ty.
wall types, core boundries + dimensions
Tue, Feb 28, 2006 at 4:29:55 AM
Wall type core boundaries
Tue, Oct 21, 2008 at 3:42:47 PM
Custom wall type controlling display in plan view
Sat, Sep 5, 2009 at 12:53:48 PM
Phantom Area Boundaries
Tue, Sep 29, 2009 at 1:12:12 PM
Any way to automaticaly find room boundaries to make finishing floor?
Wed, Sep 17, 2014 at 8:13:11 AM
Page generation time: 0.4894
