21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> wall wraps
28 Posts No Rating |
Oke guys,Could you tell me why 1 wall has the options to turn on wall wraps and the other wall (same but different name(different type)) has NOT the ability to turn on wall wraps?I'm hardly confused... I've uploaded a purged .rvt file with the 2 walls. Just try to wrap the one which isn't wrapped yet. I couldn't do it... Could someone else explain this or solve this problem?Thank you,Sef
A core layer cannot be wrapped. You need to move your Finish and thermal layers UP and then you will be able to wrap them
Thank you very much!
That solved the problem
Wall Wraps |
Fri, Oct 17, 2008 at 1:17:25 PM
13
Wall wraps at inserts |
Tue, Jun 28, 2016 at 3:50:38 PM
Door deletes when I edit wall type. |
Mon, May 1, 2006 at 2:27:03 PM
wall wraps |
Tue, Jan 31, 2006 at 4:47:15 AM
Wall wraps |
Tue, Sep 25, 2007 at 11:29:19 AM
