Forums >> Revit Building >> Technical Support >> room tags revit 2013
Tue, May 14, 2013 at 3:25:38 AM | room tags revit 2013
yoyo88
hi
im having an issue with room tags in one view all but 2 tags are shown tried visiability settings no luck any suggestions
thanks
Tue, May 14, 2013 at 5:09:32 AM | room tags revit 2013
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Have you previously selected them and turned them off? Click the light globe down the bottom left to turn on everything. If they show up unhide them. Were they created on a work set that isn't turned on? Turn on all work sets. Have they just not been placed in the room yet? Go to annotations and drop the same room tag type into the room as is in the other rooms. Have you actually selected the room yet and made it a room? Hover your mouse over the room and see if a cross appears in there which means it has actually been given a room definition.
Tue, May 14, 2013 at 5:18:41 AM | room tags revit 2013
yoyo88
i dont think i created it with filters on and have tried the light bulb with no luck its only 2 rooms in the entire project they were next to a view region.
thanks
Tue, May 14, 2013 at 5:22:15 AM | room tags revit 2013
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
View region may be causing issue. Delete it temporarily and see if they appear.
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:48 AM
Room Tags on Demo Plans
Mon, May 9, 2022 at 3:23:12 PM
Want to see Room Tags but not Rooms
Wed, Oct 5, 2016 at 11:37:51 PM
Room Tags
Thu, Feb 19, 2004 at 10:08:51 AM
Page generation time: 6.2312
