Forums >> Revit Building >> Technical Support >> How to resize spot elevations
Mon, May 13, 2013 at 3:32:49 PM | How to resize spot elevations
Archiguy
Hello all,
Trying to  reduce the size of the spot elevation icon, as it's slightly larger than the level symbols.
I went to families , and double clicked on "spot elevtions- target filled" which is the type i want to edit. I get the "type properties" box.
But I cannot make any changes here. Below the "type parameters" is greyed iut info that is not editable.
I tried the same steps after duplciating the type, but to no avail.
Appreciate any input!
thanks
Mon, May 13, 2013 at 3:35:39 PM | How to resize spot elevations
You have to edit the family - not the type.  You will find it in your browser under annotations.
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:11 AM
Spot elevations
Fri, Jul 29, 2016 at 8:01:28 AM
Revit Spot Elevations, Rooms and Color Schemes Problem
Mon, Jun 24, 2013 at 12:46:35 PM
Revit refusing to use Spot Elevations
Mon, Oct 14, 2013 at 3:47:54 PM
13
Spot elevations off by 1/4" ?
Wed, Aug 11, 2010 at 4:41:55 PM
Page generation time: 0.6243
