16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Creating Revit Topo from AutoCAD file
9 Posts No Rating |
Afternoon all,
I have an autoCAD file with topo levels (modelled with Z value)
I am trying to create a surface in Revit but it doesnt allow me to select the imported DWG and there are too many spot levels to do point by point.
Can someone help please.
Thanks
This is really easy. Just follow the directions in your HELP:
Creating a Toposurface
The help files in Revit are really good. There is some excellent videos on youtube as well.
Normally I import the dwg file and then under the site tab, I create a topo from that dwg file.
You'll probably need to massage some of the topographic levels to make it perfect but all in all its a brilliant quick result.
1 Posts No Rating |
Similar issue, just a basic question.
Civil didnt provide topo lines on thier site evaluation, only spot elevations.
Any comments/recomendations how to handle contouring with spot elevations?
All explained in your HELP. To use a points file
Also make sure the cad file isn't 'pinned' and the selection settings on the lower left isn't set to 'Not Select Pinned Elements. You can't use what you cannot select. . .
1 Posts No Rating |
countored site complete!
thanks for navigating the help, thats a lot to take in when you are trying to be quick.
creating a scv file in autocad to use in revit |
Wed, Oct 14, 2009 at 10:24:12 AM
Topo Surface from autocad into revit |
Tue, Oct 13, 2009 at 10:37:25 PM
CREATING A TOPO FROM A CIVIL CAD FILE |
Fri, Sep 29, 2017 at 3:22:33 PM
Has anyone find an accurate way of creating topo Surface from import |
Tue, May 29, 2012 at 7:42:09 AM
Importing / Modifying Topo from AutoCAD |
Thu, Feb 16, 2012 at 11:14:10 AM
