Forums >> Revit Building >> Technical Support >> Masses in separate layers
Mon, May 13, 2013 at 6:57:21 AM | Masses in separate layers
davidjohansson
When i export DWGs from my Revit 2014 project i need some mass-items to be in one layer, and other mass-items to be in a different layer.
So i can turn on and of separate layers and therefore mass-items in AutCAD.
Is there a way to fix this in layer properties in Revit?
Thanks
Mon, May 13, 2013 at 7:53:19 AM | Masses in separate layers
This is not a problem to "fix".  Change the layer in CAD.
Mon, May 13, 2013 at 7:57:29 AM | Masses in separate layers
davidjohansson
I need to do it in Revit.
So you dont know if you can do it in Revit?
Mon, May 13, 2013 at 8:05:10 AM | Masses in separate layers
Before exporting a Revit model, you may want to:
  • Reduce the amount of model geometry to be exported. See Limiting Model Geometry Before Exporting.
  • Create or modify layer mapping to ensure that all the project information stored in Revit categories and subcategories will be exported to the proper CAD layers (or levels, if exporting to DGN). Revit automatically maps categories and subcategories to preconfigured layer names. For example, a Revit door object automatically maps to A-DOOR layer in AutoCAD. You can change the preconfigured layer/level names and modify other export settings. For DGN, the information is saved in text files (see Exporting to DGN); for DWG and DXF, it is saved in export setups (see Exporting to DWG or DXF).
    For any of these formats, you can load an existing layer mapping file (current or legacy) and manually change values for it, or you can load layer settings from any of the following mapping standards:
^^^  Your answer is here
[Frustration] How to separate Autocad layers in Revit?
Mon, Jun 25, 2012 at 11:31:55 AM
Compare Two Masses in Schedule
Fri, Jan 15, 2016 at 3:24:28 PM
trouble rotating a soid mass
Thu, Aug 10, 2006 at 9:21:12 PM
Masses Don't Print?!?
Thu, Feb 24, 2011 at 2:47:51 PM
Void Masses
Fri, Oct 3, 2008 at 4:11:06 PM
Page generation time: 0.4500
