27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> error message importing DWG file into Revit
2 Posts No Rating |
I get an error message when importing a DWG base file into Revit 13. I says it can't open the file, try exploding the drawing in AutoCad and changing the proxygraphics to 1. I have done this and then saved the file, but it still won't open. I have also tried to Purge all unused items, but still does not work. Please help!!! Thank you.
I pretreat all DWG's before importing them into Revit.
This includes in the following order:
Changing the scale to millimetres (or imperial base units).
Exploding
Overkilling
Deleting anything I dont need in my revit model.
Changing all linework to layer 0
Change all linework to the same colour.
Auditing
Purging
The main aim is make the DWG file as small and simple as possible before you import it into Revit.
If you still have problems, there may be a glitch in the DWG file itself. Try creating a new blank DWG file and copying across the information from the original DWG to the new one. Go through the purge/audit process again before bringing it in.
Alternatively convert dwg to dxf and import that.
Good luck
2 Posts No Rating |
Hi,
Thank you for all your suggestions. I did them all and saved the drawing a few times to see what worked. The last one did the trick coping the content into a new drawing and re-saving. I think the oringinal drawing was corrupt and I thank you for your help. Yeah!! Now I get started. Thank you.
No problem, I'm happy to help.
Error when importing an AutoCAD File |
Wed, Oct 31, 2007 at 5:49:58 PM
Error message when importing Robot Millennium buildingmodel |
Mon, Mar 5, 2007 at 5:13:15 AM
HELP: getting "Import Geometry Not Visible" error message when linking DWG file |
Fri, Aug 17, 2018 at 8:29:02 AM
3D window error message-Revit 2009 |
Fri, Sep 15, 2017 at 2:51:33 AM
Importing CAD File - Not Appearing |
Wed, Apr 4, 2012 at 4:22:24 AM
