10 Users Online (8 Members):
Forums >> Revit Structure >> Technical Support >> Making beam family bad constraints.
1 Posts No Rating |
Hi!
I'm making a beam family from a existing one, got the idea to just make new profiles sweeping profiles to save a lot of time.But unfortunately it diden`t go that well, and I have no clue what's making it, anybody have the time to check my family and help me whit the error? Got the existing and the new one attached, as file. I don't know if its the profile or the references in the family its self that is bad.
i chechked your file.. and found out what is wrong..
when u make sweep with a profile that improted from another family, you have to link parameters of profile family to parameters of sweep family.
find the profile family you used in project browser, and select with right click, then select type properties..
then you can see type proterties window of the profile family,
in there click small buttons right of parameters, and select parameters of sweep family you want to sync...
alighnment constration is not nessesary.. that dosen't work for imported profiles just except when fix the location of whole profile family.
Edited on: Wed, May 22, 2013 at 8:58:49 PM
Edited on: Wed, May 22, 2013 at 8:59:41 PM
want more?
You can get more tips at Enjoy Revit |
and here is a video for refference..
is't for detail components but you can see how to sync parameters each other..
http://youtu.be/qbknX7XooaI
want more?
Beam System Visibility |
Wed, Mar 22, 2006 at 9:23:08 AM
Creating a beam family |
Sun, Apr 17, 2011 at 9:06:00 PM
beam revit family |
Fri, Sep 10, 2010 at 12:33:42 PM
Beam/joist going through wall |
Thu, Sep 11, 2014 at 4:32:00 PM
Family Type Constraints |
Thu, Jul 5, 2012 at 10:55:10 AM
