Forums >> Revit Structure >> Technical Support >> Change the slope of beams
Fri, May 10, 2013 at 10:04:11 AM | Change the slope of beams
Jstahl28
I received a structural model from an engineer and they set all of the roof steel at 0'-0". I need to change the heights of the beams to accomadate for roof drainage. If I were drawing this from scratch, I know I could set the underside of the roof as my work plane and just draw the beams and beam systems. Is there a way to do something similar with existing structure?
I'm using Revit 2013
Fri, May 10, 2013 at 10:21:07 AM | Change the slope of beams
The structural model should be altered.  That can be done by using a reference plane or roof to align to.
Fri, May 10, 2013 at 1:12:00 PM | Change the slope of beams
Jstahl28
I am updating the structural model. How do I move the beams that have already been drawn to the underside of the roof.
Varying roof thickness by slope change
Fri, Sep 2, 2016 at 1:25:38 PM
Extreme Slope at Roof Edge After Attaching Roof to Beams Using "Pick Supports"
Fri, Sep 28, 2012 at 11:58:23 AM
Sloping joists to the roof deck
Mon, Apr 4, 2016 at 11:21:15 AM
Aligning Beams to Slope Reference Plane
Tue, Feb 3, 2009 at 7:38:21 AM
locking an array overconstraints?
Fri, Sep 10, 2010 at 5:02:01 AM
Page generation time: 1.3189
