Forums >> Community >> Newbies >> SHAFT OPENINGS
Thu, May 9, 2013 at 10:59:40 AM | SHAFT OPENINGS
PerferAutoCad
How do I adjust just the steel in a section at a slab edge made by the shaft opening tool.  I can do it at a slab edge, but not where the slab edge was made using the shaft tool.
Thu, May 9, 2013 at 11:42:48 AM | SHAFT OPENINGS
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What do you mean adjust the steel? Attach an image of what you are trying to accomplish
Thu, May 9, 2013 at 12:20:45 PM | SHAFT OPENINGS
Sketch the hole in your floor sketch and don't use the shaft tool.
Thu, May 9, 2013 at 12:28:42 PM | SHAFT OPENINGS
PerferAutoCad
And this is what frustrates new users.  You have a very cool tool like the shaft, but the finsh product (the section on the contarct documents) is shown wrong.
Thu, May 9, 2013 at 1:23:07 PM | SHAFT OPENINGS
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I asked to see an image of what the problem is becuase I don't understand it.  What is shown wrong? Maybe WWHub knows what you mean but I think your question is to vague.
I think a lack of Revit knowledge is what frustrates most new users.. Thats not a shot at you but a lot of new users dont fully understand the capabilities or Revit even if a workaround is needed.
Edited on: Thu, May 9, 2013 at 1:25:55 PM
Thu, May 9, 2013 at 1:37:23 PM | SHAFT OPENINGS
teafoe,
I think he wasn't asking about "adjusting the steel" bur rather how to add a slab edge sweep to the floor hole created by a shaft.  I don't use shaft because of some of their problems so I sketch holes.
Way too many users don't communicate well verbally.  This industry relies on communication and we all should work at being prsice in what we say.
Thu, May 9, 2013 at 2:04:07 PM | SHAFT OPENINGS
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"How do I adjust just the steel in a section at a slab edge "
I guess this confused me.
I normally just sketch openings also.
Thu, May 9, 2013 at 3:04:11 PM | SHAFT OPENINGS
PerferAutoCad
I'm sorry I thought I was being precise.  Here’s what I mean,  See the deck stops short of the slab.
Thu, May 9, 2013 at 3:19:19 PM | SHAFT OPENINGS
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I'm still not understanding... Where does a shaft come into play?
Thu, May 9, 2013 at 3:34:41 PM | SHAFT OPENINGS
PerferAutoCad
when you make the slab opening using the shaft tool it doesn't give you the option of cutting the steel back.
Copy Monitor Shaft Openings
Thu, Oct 21, 2010 at 8:16:14 PM
A Floor That Can't Be Penetrated by Shaft Opening
Thu, Feb 20, 2014 at 2:30:48 PM
Visibility of Shaft Openings in a detail view
Fri, Apr 17, 2009 at 11:13:42 AM
Symbolic Lines not showing up in Shaft Openings
Thu, Jul 3, 2008 at 11:08:46 AM
Floor Areas and Shaft Areas
Tue, Jul 29, 2008 at 3:04:18 PM
Page generation time: 0.7373
