25 Users Online (23 Members):
Forums >> General Discussion >> Revit ROI >> Keep layer names when exporting to DWG
61 Posts No Rating |
We build our models in Sketchup. Export a 3d DWG and import that into Revit 2014 (through Conceptual mass). That way we can export sections etc from Revit.
The problem is that Revit sees the 3D DWG as a Mass, and therefore don export the layers we want.
Is there a way to "explode" the 3D DWG in Revit so it gets divided in to the layers we had before it was transformed into a Mass.
Thanks you.D
These layers...
I know everyone really liked using sketchup but it really creates problems. I think you are better off using Revit's tools to begin with. That being said: Have you tried this?
If they are linked instead of imported, will they then export as a linked CAD file.
Dont really understand you last comment, is it a question?
If the 3D DWG:s are linked you can´t make section cuts through them. You have to open them through Conceptual mass and then import them in to the project. And when i do that the layers dissapear.
All i really want to know is if there is a way to "explode" the 3D DWG in Revit so it gets divided in to the layers we had before it was transformed into a Mass? I know its not standard procedure but if you know some tricks i would appreciate it!
Thank you.
OK .. Then your answer is no. There are no CAD layers in REVIT so exploding a faile only creates REVIT elements.
Layer names |
Mon, Aug 15, 2005 at 9:15:07 PM
Exporting and layer modifiers |
Wed, Nov 16, 2011 at 4:04:33 PM
Exporting revit drawings to .dwg |
Wed, Aug 10, 2005 at 10:36:23 PM
Problem with Exporting to dwg with multiple layers for use in 3D Studio |
Mon, Dec 13, 2004 at 5:21:21 AM
Exporting scope boxes to dwg |
Fri, Jul 1, 2011 at 12:30:25 AM
