Forums >> General Discussion >> Revit Project Management >> Wall Sections Showing up on Both sides of building
Wed, May 8, 2013 at 2:52:31 PM | Wall Sections Showing up on Both sides of building
depersia
I have a wall section that is showing up on both the north and south elevation of my building eventhough I've drawn in only cutting through the north facade.  (Plan attached)
What setting am I missing.
I only want the section to appear on the elevation I'm cutting it through.
Thanks!
Wed, May 8, 2013 at 2:58:12 PM | Wall Sections Showing up on Both sides of building
Why do you set your elevations to show the full depth of the building?  That just means Revit has to deal with everything in the view including your wall sections on the other side.  Goto your plan view and drag your elevation depth back to where it only includes items that elevate on that side.
Wed, May 8, 2013 at 2:59:00 PM | Wall Sections Showing up on Both sides of building
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I believe in elevation sections will show up eitherway.  You will just need to hide it.
Wed, May 8, 2013 at 3:18:29 PM | Wall Sections Showing up on Both sides of building
No teafoe - If the view range doesn't intersect the section, it will not show.  We always set our elevations to clip / without line.
Wed, May 8, 2013 at 3:28:30 PM | Wall Sections Showing up on Both sides of building
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Ah yes you are correct
Wed, May 8, 2013 at 4:13:39 PM | Wall Sections Showing up on Both sides of building
depersia
Thanks guys!
That was my problem. I didn't realize I had my elevations set up without  a clip distance.
Much appreciated.
Annotating Building Sections/Wall Sections/Details [ 1 2 ]
Thu, Mar 17, 2011 at 2:54:40 PM
15
unlock finish materials on both sides of wall
Wed, Mar 30, 2011 at 4:14:42 AM
Roof not showing all layers of sructure in some sections
Fri, Sep 15, 2017 at 1:25:04 AM
11
Building Section callout not showing in plan views
Fri, Mar 11, 2016 at 3:41:54 PM
Revit 2017 Mising Wall Sections
Mon, Jul 18, 2016 at 5:53:08 PM
Page generation time: 3.3641
