Forums >> Revit Building >> Technical Support >> Curtain Wall Snapping
Wed, May 8, 2013 at 1:13:04 PM | Curtain Wall Snapping
shulenj
4 Stars: 4 Votes
Im trying to create a curtain wall embeded in a solid wall. This isnt the problem.
My problem is that the end of the wall will always snap to one place when it is within a foot of that space. There is no significance to that space, it is not the end of another wall, there is no grid there. There is no significance to this spot other than it attracting my curtain wall.
I have tried redrawing, but it always snaps to the same space. I have tried drawing half the wall and then extending it to the right spot, but it still esnaps to that spot. I have tried mirroring 2 walls, it still snaps. I have tried entering the correct legnth, but it snaps right back to the spot. I need to free the end of this wall from the super magnet i apparently modeled
Revit 2013
-Jeff
Intern Architect
Waldon Studio Architects & Planners
Columbia, MD
Wed, May 8, 2013 at 1:15:50 PM | Curtain Wall Snapping
Turn off the wall join for the end of the wall and see what happens.  This wall is still joining with another wall - probably above or below what you can see.
Wed, May 8, 2013 at 1:21:29 PM | Curtain Wall Snapping
shulenj
4 Stars: 4 Votes
This is a wall that has been redrawn 5 times. I double checked, if theres a join left on this wall, there is no way to get rid of it. Its still snaping
Interesting plot twist. I can edit it more freely in elevation, however the second it is touched in ANY way in plan it resnaps
-Jeff
Intern Architect
Columbia, MD
Wed, May 8, 2013 at 1:24:59 PM | Curtain Wall Snapping
Did you turn off the wall join? ? ?  I don't think so!
Click on the CW - then the blue dot at the end and turn off wall join.
Edited on: Wed, May 8, 2013 at 1:25:57 PM
Wed, May 8, 2013 at 1:30:10 PM | Curtain Wall Snapping
shulenj
4 Stars: 4 Votes
Join condition is undefined, I unjoined geometry to everything I could click in either view, and I cycled through wall join conditions with no change on any of the options I clicked. like I said, if theres a join left on this wall, its a mystery to me
-Jeff
Intern Architect
Columbia, MD
Wed, May 8, 2013 at 1:34:10 PM | Curtain Wall Snapping
shulenj
4 Stars: 4 Votes
Well, it did fix the problem on the one side...but now I have it on the other side and disallowing join isnt helping it
-Jeff
Intern Architect
Columbia, MD
Wed, May 8, 2013 at 1:49:52 PM | Curtain Wall Snapping
shulenj
4 Stars: 4 Votes
Fixed. It was not just the joining issue, but on the opposite side it was also glitching with a wall from another phase. Double trouble essentially. Thanks
-Jeff
Intern Architect
Columbia, MD
Wed, May 8, 2013 at 1:57:01 PM | Curtain Wall Snapping
I am not talking about join geometry.  All walls in Revit have a switch that can be set that allows them to join or not.  Please list.... click on the wall then right click on the blue button and pick disallow join!
curtain wall sketch snapping problem
Wed, Aug 12, 2009 at 8:54:07 AM
Curtain walls
Fri, Dec 14, 2012 at 5:47:46 PM
Spot Elevations - Random snapping.
Tue, Feb 21, 2017 at 6:19:05 AM
Curtain Wall Panel to Curtain Wall Door
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:44 PM
Page generation time: 1.8675
