Forums >> Revit Building >> Technical Support >> Ceiling tags - parametric
Fri, Feb 3, 2006 at 3:25:15 PM | Ceiling tags - parametric
rcollins
Their must be a simple label that I can use to annotate the ceiling height of a room on the ceiling plan. I haven't found it. Can someone help me? Thanks
Fri, Feb 3, 2006 at 6:04:44 PM | RE: Ceiling tags - parametric
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes a ceiling tag. You just need to add the appropriate label in the tag for offset from level.
Thu, Jun 7, 2007 at 10:51:36 PM | Ceiling tags - parametric
jesseinvt
The ceiling height tag is in the Imperial Library--Annotations--Architectural folder.  I wanted a ceiling tag showing the height only so I deleted all the other info from the family.  It's a bit tricky to place this tag, but it is a nice parametric tag!
Multiple Ceiling Tags
Mon, Jul 21, 2008 at 5:25:13 PM
Ceiling Tags
Tue, Jun 24, 2008 at 4:58:13 PM
Parametric Suspended Ceiling Hangers
Tue, May 19, 2009 at 10:32:57 AM
room tags in ceiling plan?
Wed, Jun 14, 2006 at 4:30:44 PM
ceiling tags`
Thu, Sep 8, 2005 at 2:53:00 AM
Page generation time: 0.3674
