Forums >> Revit Building >> Technical Support >> Louvred effect wall - best way to create it?? help!!
Tue, May 7, 2013 at 10:49:58 AM | Louvred effect wall - best way to create it?? help!!
landofdan
I need to create a Wall with Louvred effect (see attached)
I've tried using a curtain wall and replacing the panels with different louvre panels but i end up with alot of messing about, Doors dont seem to want to cut properly and it you can see through the wall from the inside.
Does anyone have any advice on the best way to do this?
Ideally i need a normal wall finish on the inside with that finish on the outside and so doors/ louvers can cut into it.
Thanks
Dan
Im using Revit Architecture 2012.
Tue, May 7, 2013 at 10:55:07 AM | Louvred effect wall - best way to create it?? help!!
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I would just use a material for this instead of trying to model it.
curtain wall louvres
Mon, Jul 18, 2005 at 10:27:01 AM
Hand-drawn effect
Thu, Jun 19, 2014 at 12:30:00 PM
Peeling paint effect on wall
Wed, Feb 23, 2011 at 2:41:44 PM
How to create a wallpaper effect/pattern...
Thu, Jun 9, 2011 at 7:08:31 PM
Waterfall effect in Revit files
Sun, Oct 20, 2019 at 7:46:58 AM
Page generation time: 2.9654
