Forums >> Revit Systems >> Technical Support >> Ellipse railing
Tue, May 7, 2013 at 4:51:58 AM | Ellipse railing
gelo26
4.5 Stars: 2 Votes
Hi, may I ask if there's a way to create a railing with ellipse path.
Tue, May 7, 2013 at 7:15:02 AM | Ellipse railing
Why do an absolute ellipse?  They are hard to define and build.
When we hand drafted and needed an ellipse (before templates '60's), we always used an approximation as described in the first link below.
http://etc.usf.edu/clipart/76200/76201/76201_ellps_4cntr.htm
This link shows how close an appromation is to a real ellipse - note that very long, thin ellipses do not work as well.
 http://www.uwgb.edu/dutchs/MATHALGO/Ellipses.HTM
If you do like described in those links, you use simple arcs and those work with all Revit elements.
Tue, May 7, 2013 at 10:34:19 PM | Ellipse railing
Thread Post Kudo! #3
gelo26
4.5 Stars: 2 Votes
actually the design requires to have an ellipse path for railing (please see attach image) its an indoor track-4 lanes and because of space requirement, we came up with this design. ellipse are so annoying, you cant even use them in pick lines command for walls.
Wed, May 8, 2013 at 12:07:44 AM | Ellipse railing
CDWdavid
5 Stars: 5 Votes
Hi Gelo26,
Please do not use ellipse for running track!
I designed the year 2000 US Olympic Trial track, and myself was a runner too.
Please use simple half circle, all other shapes we called "back-breaker".
Edited on: Wed, May 8, 2013 at 1:54:56 PM
Wed, May 8, 2013 at 12:51:06 AM | Ellipse railing
gelo26
4.5 Stars: 2 Votes
thank you for your reply and comments. as much as i want to have a semi circle for the track, my boss insists to have this layout. i'll defend this to him and update you guys if i win over my boss. cheers!
Wed, May 8, 2013 at 2:41:50 AM | Ellipse railing
gelo26
4.5 Stars: 2 Votes
i won! thanks wwhub and cdwdavid for your advise.
Wed, May 8, 2013 at 2:30:49 PM | Ellipse railing
CDWdavid
5 Stars: 5 Votes
Cheers!
You have a wonderful and open-minded boss.
problem with ellipse
Fri, Apr 13, 2007 at 10:29:32 PM
Dimensioning an Ellipse?
Thu, Apr 24, 2008 at 12:16:07 PM
Double ellipse mass
Wed, Nov 5, 2008 at 1:59:06 AM
Glazing wall with ellipse form
Tue, Feb 28, 2006 at 4:44:41 AM
Creating an ellipse wall
Fri, Jun 26, 2009 at 10:16:44 AM
Page generation time: 0.7199
