Forums >> General Discussion >> Revit Project Management >> Rebar Reinforcment Material takeoff
Sun, May 5, 2013 at 1:46:33 PM | Rebar Reinforcment Material takeoff
pcarcort
I want to know about your experience using Material Takeoff.I need to make a schedule of rebar of all concrete columns and beams of a 12 level building.
I need to show the total weight of reinforcement
Do you know the best method to do that?.
Tue, May 7, 2013 at 11:34:14 AM | Rebar Reinforcment Material takeoff
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Unless you actually model all of the rebar in Revit (which I don't suggest) you will most likely have to do this by hand.  You might also be able to add a shared parameter to include in your beams and columns for rebar sizing, lengths, etc. and then use a multi-catagory tag to schedule the information.  Not sure how this would help with total weight however, you would still most likely need to do that by hand.
Material Takeoff
Mon, Apr 27, 2015 at 7:32:15 AM
Ceiling Material Takeoff
Thu, Feb 15, 2007 at 3:19:57 PM
Material Takeoff issue
Mon, Oct 25, 2010 at 3:48:35 PM
Material Takeoff for insulation??
Mon, Oct 28, 2013 at 9:57:10 AM
Sheathing Material Takeoff
Mon, Apr 25, 2011 at 7:01:06 AM
Page generation time: 3.3400
