Forums >> Revit Building >> Technical Support >> Wall with battens
Sat, May 4, 2013 at 7:05:14 AM | Wall with battens
SteveB
3.5 Stars: 5 Votes
Is there a way to make a wall that has vertical battens inherent in the wall family itself?  I know one can place battens as wall sweeps manually (per this thread: http://www.revitcity.com/forums.php?action=viewthread&thread_id=20227  )
Sun, May 5, 2013 at 8:43:24 AM | Wall with battens
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
If I've ever had battens in my walls, I just set it as a layer within a wall - it's thickness the thickness of the batten. I would then only show battens as 2D lines/ infils/masks when I did a plan or section detail.
Wall with horizontal and vertical battens
Thu, Apr 22, 2010 at 4:01:20 PM
Angled battens
Fri, Jun 13, 2008 at 4:22:34 PM
Wall with exterior vertical battens
Mon, Jun 12, 2006 at 10:23:53 PM
Creating gable battens.
Tue, Jan 13, 2004 at 9:12:54 AM
Adding Battens to Wall
Mon, Nov 19, 2007 at 3:33:19 PM
Page generation time: 0.8497
