Forums >> Revit Building >> Technical Support >> symbolic lines on awning windows
Fri, Feb 3, 2006 at 12:54:32 AM | symbolic lines on awning windows
leeroy
every time I try to increase the width of my awning windows, the symbolic lines that have been drawn to indicate the opening sash skew out of shape. is there a way of ensuring that these lines stay in the middle of the sash?? Post edited on 2006-02-03 00:54:59
Fri, Feb 3, 2006 at 9:42:24 AM | RE: symbolic lines on awning windows
eldados
eldados Avatar
4.5 Stars: 8 Votes
yes, you will need to lock the lines in your family, click on your lines and a dimension should appear, just lock it...
Integrator
KarelCAD
Fri, Feb 3, 2006 at 6:08:56 PM | RE: symbolic lines on awning windows
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes. Lock the end points to the appropriate reference planes. Then add an equal dimension to make it stay in the centre.
Fri, Feb 3, 2006 at 7:11:37 PM | RE: symbolic lines on awning windows
leeroy
oh my f_____g god where were you guys 2 days ago . much appreciated
Symbolic lines
Tue, Dec 26, 2006 at 2:24:22 AM
Windows above the Cutplane and Symbolic Lines (Revit2010)
Wed, Jul 14, 2010 at 7:35:42 AM
Simbolic Lines in CW Awning Windows
Thu, Oct 15, 2015 at 3:49:00 PM
creating symbolic lines for bifold windows
Sat, Feb 11, 2006 at 12:27:19 AM
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:17 PM
Page generation time: 1.1546
