Forums >> Revit Building >> Technical Support >> Problems with elipses
Sat, May 29, 2004 at 3:29:45 PM | Problems with elipses
stirrup
Anybody know how to overcome the problem that the new eliptical tool doesn't work in massing or solid modelling. Regards Duncan Hammond aka STIRRUP
Sat, May 29, 2004 at 4:29:02 PM | RE: Problems with elipses
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Well if the elipitical tool doesn't work in massing, I know it works when creating in-place families so you could always use this to do all the elipitical objects. If they need to attach to anything, ie: a roof. Be sure to use an appropriate family that allows attaching to the correct element. Cheers, Chris.
Regards,
Chris.
Solid Blend problems
Mon, Jul 20, 2009 at 4:04:05 AM
Family Typical Model based on line
Mon, Dec 22, 2008 at 7:32:06 AM
Dimensioning an Ellipse?
Wed, Jan 23, 2008 at 2:02:51 PM
Elipse and slanding
Fri, May 26, 2006 at 2:33:20 AM
Installation Problems
Workflow & Implementation >> Chameleon
Mon, Jan 14, 2013 at 12:07:30 PM
Page generation time: 2.7172
