Forums >> Community >> Newbies >> Roof Plan not Showing in Site Plan
Wed, May 1, 2013 at 9:26:34 AM | Roof Plan not Showing in Site Plan
jsego
Hello,
I am having trouble when I go to site plan view, the roof plan is now showing, and interior walls are showing instead.  I know this is the view range, but every number and level combination I try, it still will not show.  My building is 30' feet tall.
Thank you!
Wed, May 1, 2013 at 9:29:14 AM | Roof Plan not Showing in Site Plan
jsego
Sorry, the file didn't attach correctly.
Wed, May 1, 2013 at 9:39:04 AM | Roof Plan not Showing in Site Plan
Change the cut plane of your view in view properties.  It is too low.  Pick something like 100'
Wed, May 1, 2013 at 10:03:33 AM | Roof Plan not Showing in Site Plan
jsego
Thanks for your input.  I did and still nothing.  See my view range attached.
Wed, May 1, 2013 at 10:05:33 AM | Roof Plan not Showing in Site Plan
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Your CUT PLANE is set to 10'-0"  not 100'-0" like WWHUB said to do
Wed, May 1, 2013 at 10:11:49 AM | Roof Plan not Showing in Site Plan
jsego
I did that and still nothing.  I took the picture before I changed it.
Wed, May 1, 2013 at 10:12:47 AM | Roof Plan not Showing in Site Plan
jsego
Wed, May 1, 2013 at 10:15:39 AM | Roof Plan not Showing in Site Plan
jsego
Thanks everybody.  I just figured it out.  I had to model my roof with ceilings and the ceilings are not turned on in visibility and graphics for site plans.
Wed, May 1, 2013 at 10:19:07 AM | Roof Plan not Showing in Site Plan
This is user error.
Your not telling us something.  The roof is maybe not on - hidden - in a different phase - in a different workset or 100+ feet in the air.
Wed, May 1, 2013 at 10:21:19 AM | Roof Plan not Showing in Site Plan
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You modeled your roof with ceilings????? Why
Wed, May 1, 2013 at 10:24:48 AM | Roof Plan not Showing in Site Plan
#11
jsego
Yeah, I know.  This is for a school project and I'm still fairly new to Revit.  My ceiling/roof is hard to explain...stepped concrete that are all stepping in different ways.  I had no idea how to model this with a roof.
Wed, Jul 12, 2017 at 12:03:32 PM | Roof not showing!
#12
valdezz
hello am new to revit. when i use the command roof on my plan it does not appear i can only see the rectangle the roof command created when i used the pick wall command and on 3d it appears as a slab .really need help. thanks in advance
Roof Plan Issues- lower roof showing above upper roof
Thu, Dec 10, 2015 at 3:10:46 PM
Cars not showing in renderings but showing in site plan, help hurry please
Fri, May 6, 2011 at 6:01:49 PM
nested generic annotations visible on site plan and roof plan
Thu, Feb 10, 2011 at 8:04:15 PM
Walls from multiple floors above showing in site plan
Wed, Oct 3, 2012 at 9:23:52 PM
Invisible Roof in Ceiling Plan
Mon, Nov 14, 2011 at 11:53:58 PM
Page generation time: 2.9647
