Forums >> Revit Building >> Technical Support >> stretcher bond with mortar joint - custom
Tue, Apr 30, 2013 at 2:41:34 PM | stretcher bond with mortar joint - custom
bjwson
2.5 Stars: 3 Votes
hi,
i have copied this pattern from revit city, 1. its not behaving like a model pattern, 2. i cant understand the values in the patern, are they in cm,inches or in mm etc.
can some one here help me with the same pattern but with custom values for metric system.
horizontal mortar joint is 20mm wide and vertical joint is 10mm wide and the panel or the brick pattern size is 1790x780mm
pls. see the pattern below
*Brick w/ Mortar,brick w/mortar TIP500 (c)1990, Buddy Pentecost
;%TYPE=MODEL;
0,  0.02, 0.02, 0, 1, 0.96, -0.04
0,  0.02, 0.48, 0, 1, 0.96, -0.04
0,  0.52, 0.52, 0, 1, 0.96, -0.04
0,  0.52, 0.98, 0, 1, 0.96, -0.04
90, 0.02, 0.02, 0, 1, 0.46, -0.54
90, 0.98, 0.02, 0, 1, 0.46, -0.54
90, 0.52, 0.52, 0, 1, 0.46, -0.54
90, 0.48, 0.52, 0, 1, 0.46, -0.54
Tue, Apr 30, 2013 at 2:49:10 PM | stretcher bond with mortar joint - custom
Add this line in your heading and see what happens:
;%UNITS=INCH
Change it to metric and see how it works.  I think its metric because it sure doesn't look like inches.
Tue, Apr 30, 2013 at 7:27:00 PM | stretcher bond with mortar joint - custom
hugh
3.5 Stars: 4 Votes
That pattern looks like it is expressed in feet, which is ironically usless for Revit as despite Revit storing all lengths internally as feet it requires pattern to be input as inches or millimetres.
Anyhow, try this:
;%VERSION=3.0
;%UNITS=MM
*MODELBRICK1800X800,horizontal 1790mmx780mm bond=1/2
;%TYPE=MODEL
;        Pattern written by HatchKit v2.7 Hatch Pattern Editor
;        HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2013.
;        www.hatchkit.com.au
;-Template=Brick1800x800,horizontal 1790mmx780mm bond=1/2
;-Date    =1/05/2013
;-Time    =10:17:36 AM
-90,1790,780,800,900,780,-820
90,0,0,800,900,780,-820
0,0,780,900,800,1790,-10
180,1790,0,900,800,1790,-10
Hugh Adamson
www.hatchkit.com.au
Mon, May 6, 2013 at 3:10:08 AM | stretcher bond with mortar joint - custom
bjwson
2.5 Stars: 3 Votes
Many Thx.
In 2012, appears we have lost the ability to click on the mortar joint...
Tue, May 3, 2011 at 7:37:43 AM
Custom Running Bond Brick Pattern
Fri, Aug 26, 2016 at 2:38:25 PM
Creating joint lines!!??
Mon, Mar 27, 2006 at 10:59:33 AM
A Rebar/ Bond Beam Family Question
Mon, Nov 5, 2012 at 7:08:20 AM
conc block pattern is not showing correctly
Wed, Mar 14, 2007 at 3:38:26 PM
Page generation time: 0.7220
