Forums >> Revit Building >> Technical Support >> Project North and True North
Thu, Feb 2, 2006 at 6:16:50 PM | Project North and True North
saipanda
I have a site survey map with countours and coordinates. I want to import that and make a terrain model (toposurface) and design houses/buildings. First I tried importing the survey drawing as is (True North), and then, rotated the project north in plan views etc. This worked fine until I noticed that the shadows may be cast incorrectly when I rendered... So next, I tried rotating the survey drawing first, and then imported into Revit. For the site plan, I used Project North. But this way, you lose the true coordinates. What is the proper way to do this?
Fri, Feb 3, 2006 at 6:20:18 PM | RE: Project North and True North
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You should always begin drawing your building/site the way in which you want to document it. Once you are concerned with the direction of True North you can then use the "Rotate True North" command to tell revit where North is (note you'll need to have the view set to true north in order to do this). Import the survey, drawing then rotate it to the orientation you wish to document it in (take note of how much you rotated it by). Then use the Rotate True North to rotate it back to advise Revit where north is. HTH.
Project North doesn't rotate back after changed to True North
Fri, May 7, 2010 at 3:24:14 AM
True North vs Project North Linked dwgs
Thu, Mar 10, 2016 at 10:02:26 AM
project north/true north
Thu, Mar 17, 2005 at 5:00:19 PM
True North / Project North spelled out
Sun, Jun 10, 2012 at 1:41:04 PM
EXPORTING TO FBX TO TRUE NORTH
Wed, Sep 9, 2015 at 7:36:58 AM
Page generation time: 2.1831
