Forums >> Community >> Newbies >> Material not showing up in shaded view.
Tue, Apr 30, 2013 at 7:03:23 AM | Material not showing up in shaded view.
niteshrupalia
Hey guys, i've been using revit for quite some time at a very basic level. I have recentley upgraded to Revit 2013. When I click shaded view on in 3d perspective, everything turns up grey. I have checked the materials and have selected use render appearance for shaded view, when I click that the colour underneath turn Grey, but the material is clearly colour stone.
Been stuck on this for quite some time, any help will be appreciated. Thanks!
Nitesh
Tue, Apr 30, 2013 at 7:56:32 AM | Material not showing up in shaded view.
All materials in Revit have to be assigned.  If it's grey - then you probably have not assigned it anything. Shaded view colors are assigned separately from rendered color.  Do some reading on Revit's materials and how to assign them.
Tue, Apr 30, 2013 at 3:04:49 PM | Material not showing up in shaded view.
niteshrupalia
I have assigned them, I had no problems doing it in revit 2012, just revit 2013 dosn't seem to show the material. I have attached a screen shot of what happens when I tick the box.
Tue, Apr 30, 2013 at 3:45:44 PM | Material not showing up in shaded view.
niteshrupalia
come on guys 20 vews some one must have the answer. If it help when I go to render all the materials comeout fine, just in 3d perspective shaded view.
Wed, May 1, 2013 at 7:14:57 AM | Material not showing up in shaded view.
4 Stars: 205 Votes
I can't see where is the problem, everything is ok, in your 3D view change to "Realistic Mode", now you'll see the mat.
Wed, May 1, 2013 at 8:32:06 AM | Material not showing up in shaded view.
niteshrupalia
only reason every thing looks ok in 3d view is because, i set material shading to a certain colour, but if i use the tick box for use render material, then it goes grey.
Wed, May 1, 2013 at 12:07:40 PM | Material not showing up in shaded view.
4 Stars: 205 Votes
No problem here.
Wed, May 1, 2013 at 12:10:02 PM | Material not showing up in shaded view.
Your material may be corrupted.  Try something else and see if that works.  If it does, then the problem is the material.
Mon, May 6, 2013 at 5:19:18 PM | Material not showing up in shaded view.
niteshrupalia
material was corrupted!! THANK YOU
In shaded View walls/roofs are showing material and lines behind them
Tue, May 28, 2013 at 9:35:44 AM
Topo material color not showing?
Thu, Nov 26, 2020 at 11:24:41 AM
2013 Wire Frame Showing in Shaded Mode
Thu, Apr 25, 2013 at 7:06:56 AM
Wireframe lines showing up in Shaded 3D View
Thu, Apr 2, 2009 at 11:36:35 AM
why shading material color gets overridden by surface color
Wed, Apr 25, 2018 at 9:53:40 AM
Page generation time: 3.1891
