Forums >> General Discussion >> Revit Project Management >> Using View Name as Label Parameter.
Mon, Apr 29, 2013 at 4:12:44 AM | Using View Name as Label Parameter.
archizen
Can I use view name as a label parameter to show it on my titleblock.I know it already appears on title w line but i want it also somewhere else.Are there better ways than using shared parameters?
Mon, Apr 29, 2013 at 7:30:23 AM | Using View Name as Label Parameter.
"... but i want it also somewhere else...."  << We can't read your mind.
You can create your own view title - not just title with line.
Mon, Apr 29, 2013 at 7:43:49 AM | Using View Name as Label Parameter.
archizen
hahaha! sorry bout my bad english.I mean somewhere else on my titleblock.
I'm not asking about how to create view title.
I'm tryin to design a titleblock.i want my view name just appears on my titleblcok by using label.but there is no parameter for view name,deppite there are parameters for scale,sheet name or etc..i dont wanna use shared parameter n write name of view one more time.im just asking if there is a better way to do it instead of writing a shared parameter.i hope i make my self clear.
Mon, Apr 29, 2013 at 7:48:49 AM | Using View Name as Label Parameter.
Sorry but you can't do this as far as I know.
For most users, sheets have multiple views so this provision is just not typical.
You can always create a view title of the right size and drag that over into your titleblock area.
View Parameter & Label
Mon, May 15, 2017 at 4:53:26 PM
Blank line in text label
Fri, Sep 16, 2011 at 4:07:46 PM
label parameter formula
Thu, Apr 26, 2012 at 12:15:03 PM
Instance Parameter to control another Instance Parameter
Thu, Jul 22, 2010 at 6:22:48 AM
view label rotation plan view
Tue, Dec 30, 2014 at 11:17:50 AM
Page generation time: 1.1963
