Forums >> Revit Building >> Technical Support >> Help! Print settings changed and don't know what to fix
Sat, Apr 27, 2013 at 9:47:39 PM | Help! Print settings changed and don't know what to fix
designnit
So I must have changed a setting somewher and only my 2nd floor is printing like crap. With and without shadows, print to PDF or export to TIF
All my other plans, elevations work fine, I have tried to fix the settings to match on the sheet and the view with no avail....Has this happened to anyone?
Using Revit 2013
119163_Hotel_Tvaalittle.tif
Sun, Apr 28, 2013 at 10:30:24 AM | designnit
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting designnit from 2013-04-27 21:47:39
Using Revit 2013
make a quick template from a like view that is showing correctly and apply it to the view in question.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, Apr 28, 2013 at 10:49:10 AM | Help! Print settings changed and don't know what to fix
designnit
I save a new print template and it still is printing "unfocused" here is the new PDF. Could it be anything with the components on this floor?
here is the DB file location.
https://www.dropbox.com/s/0ui7toospklyhnv/Hotel%20Tvaalittle.rvt
Sun, Apr 28, 2013 at 11:11:10 AM | Help! Print settings changed and don't know what to fix
coreed
coreed Avatar
4 Stars: 16 Votes
I was referring to a view template, I don't know what a print template is. Also are printing raster or vector?
Edited on: Sun, Apr 28, 2013 at 11:11:36 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, Apr 28, 2013 at 12:28:51 PM | Help! Print settings changed and don't know what to fix
designnit
It worked!! I have no clue what setting I changed, but I have a ledgable floor plan, thanks to you.
Also I was printing Raster due to the shadows needed.
Thanks!
elevation arrowhead don't show up at print
Tue, Nov 14, 2006 at 1:26:57 PM
Masses Don't Print?!?
Thu, Feb 24, 2011 at 2:47:51 PM
Materials don't print in some areas (Revit Arch 2008)
Fri, Feb 8, 2008 at 4:11:31 PM
What I see in revit I do not print
Thu, Mar 3, 2016 at 10:35:35 AM
Detail components won't print
Thu, Mar 28, 2013 at 7:15:48 AM
Page generation time: 5.8705
