Forums >> General Discussion >> Revit Project Management >> AutoCAD and Revit
Sat, Apr 27, 2013 at 4:57:42 PM | AutoCAD and Revit
csantocristo
So I am starting a project and I have all the AutoCAD files I imported into Revit and did a full explode, My questions are these:
1) How do I edit line types, after I explode the AutoCAD drawing and select the individual lines I can't edit the lines, the "edit type" is grayed out how do I fixe this?
2) When I draw a new line the lines comes out as a green line, which I dont know what that means or how to fix it.... and when I select this line I still cannot edit type....
Any help would be appreciated.
Thanks Cory
Sun, Apr 28, 2013 at 10:34:27 AM | AutoCAD and Revit
coreed
coreed Avatar
4 Stars: 16 Votes
Exploding Autocad files in Revit is not a recommened work flow. Your problems are only being.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, Apr 28, 2013 at 10:29:06 PM | AutoCAD and Revit
RevitBJO
Did you draw a 'reference line' instead of an actual 'detail line'
If you have 2D AutoCAD files, then the best practice is to insert them into a container file which you can link into your main project. This will ensure you never corrupt your main modelling file. Also, as said by 'coreed', never explode AutoCAD files. There really shouldn't  be any reason to this, so try and link them and your file will update with new editions of a particular CAD file with the same name.
Also, just reading your post again. Why are you trying to edit linetypes from the CAD file ? Are you not using the CAD files as an overlay to do your modelling. Your 2D linework will be driven by your model element projection and cut lines ?
Mon, Apr 29, 2013 at 7:23:19 AM | AutoCAD and Revit
As coreed says - exploding CAD files is a bad practice but I have to add - exploding in your project file.  If you really need CAD linework, bring it into a clean up project.  Explode it there and:
  1. Convert all linework to your standard lines (pick all the lines of one type and change to your type)
  2. Replace all filled regions with your standard regions
  3. Delete dimensions and add revit dimensions
  4. convert text to your standard
  5. delete arrows
Now you can copy / paste into your project.
You can always link in a CAD file and use pick lines to trace elements you want - then remove the link.
AutoCad vs Revit [ 1 2 ]
Thu, Aug 4, 2011 at 1:58:52 PM
16
Why doesn't reivt have the simple autocad commands that we know and love. [ 1 2 ]
Thu, May 7, 2009 at 1:22:38 PM
15
Autocad details linked into Revit
Mon, Jun 6, 2016 at 1:54:23 PM
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
Revit or AutoCAD?
Mon, Feb 22, 2010 at 2:49:07 PM
Page generation time: 1.6763
