Forums >> Community >> Newbies >> Changing line patterns and weight below the ground line
Fri, Apr 26, 2013 at 3:37:06 PM | Changing line patterns and weight below the ground line
cbuchert
Hey. This is my first time posting.
I'm a student. I love Revit. It allows me to do some amazing things in model and pull and update data rediculously quickly. One thing that has eluded me so far has been how to change line styling below ground. Tradidionally, I could select the lines I had drawn in a CAD application (take your pick) and just change the line weight or style. However, I cannot find any way to do this in Revit without changing line styles for an entire object or family. Help!
Thanking you in advance,
Chris.
Mon, Apr 29, 2013 at 7:24:23 AM | Changing line patterns and weight below the ground line
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You could use the Linework tool under the Modify tab or click on the element right click and chose Override Graphics in View and  chose by element (probably your best bet).
changing line weights of hatch patterens
Sun, Dec 11, 2005 at 8:01:22 PM
Changing line weights to hatching?
Wed, Apr 26, 2006 at 10:44:00 PM
Changing line weight of callout bubbles?
Thu, Sep 21, 2006 at 2:38:28 PM
Filters, Fill/Surface Patterns and Halftone or Line Weight?
Fri, Feb 18, 2011 at 3:11:12 PM
changing property line weight in Revit 2009
Thu, Jun 18, 2009 at 12:58:52 PM
Page generation time: 0.9037
