Forums >> Revit Building >> Technical Support >> Exporting to Autocad with Masking Regions
Wed, Apr 24, 2013 at 4:17:34 PM | Exporting to Autocad with Masking Regions
jwetmore
I am using REVIT 2013 and am having problems when I export to autocad.  We have several images on the sheets.  These images need to be cropped and since REVIT cannot crop we are using masking regions to cover up the areas we don't want to see.  But when the sheet is exported to autocad, the masking regions disapear.  In the autocad file I can see the areas of the image that I don't want to see.
Any idea why this is happening and how it can be corrected?
Thanks
Wed, Apr 24, 2013 at 7:57:52 PM | Exporting to Autocad with Masking Regions
ronmalit
5 Stars: 3 Votes
normally, i used filled region and can export nicely.
using CP83 option.
thanks
** dont be mad, i dont have much... i am homeless
Thu, Apr 25, 2013 at 7:15:50 AM | Exporting to Autocad with Masking Regions
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You don't you crop the images to how you need them before bringing them into Revit?
Thu, Apr 25, 2013 at 7:45:52 AM | Exporting to Autocad with Masking Regions
jwetmore,  Revit does crop so please expand your question to clarify.
Revit also will export masking regions but they may be turned off in the CAD file.  Turn them on in CAD.
Thu, Apr 25, 2013 at 9:19:10 AM | Exporting to Autocad with Masking Regions
You can't cut a drafting view- draw it right.
All model views can be cropped.  Turn on crop region, adjest it and turn on crop view.  << In view properties.
CAD masking is no a layer - it is a setting in CAD.  I believe it is fillmode.
Thu, Apr 25, 2013 at 9:25:54 AM | WWHub
jwetmore
Quoting WWHub from 2013-04-25 07:45:52
I checked the CAD file again.  All of the layers are turned on so I don't think that the regions are there.  If you have found a way to crop an image in REVIT please let me know.  I can't crop the image and I can't crop a drafting view.
Thu, Apr 25, 2013 at 9:33:42 AM | WWHub
jwetmore
Quoting WWHub from 2013-04-25 09:19:10
I tried changing the fillmode and it has no affect.  Do you have any other ideas?  The image that needs to be cropped is in a drafting view so the view cannot be cropped.  I cannot crop the image in REVIT because it does not have the capability.  I cannot edit the image file because REVIT does not link images so I would have to replace all of the images (about 100) after I edit them.  Adding masking reagions does not work when it is exported to Autocad (unfortunately the client insists that it be exported to Autocad)
Edited on: Thu, Apr 25, 2013 at 9:43:14 AM
Thu, Apr 25, 2013 at 9:49:34 AM | Exporting to Autocad with Masking Regions
2013 My Revit and my CAD export.  Masking region was not exported but actuall cropped the elements.
Thu, Apr 25, 2013 at 9:54:14 AM | Exporting to Autocad with Masking Regions
Fillmode is for filled regions - like a solid fill.  Use a masking region - not a white solid fill.
Thu, Apr 25, 2013 at 9:56:54 AM | WWHub
jwetmore
Quoting WWHub from 2013-04-25 09:49:34
Yes it works fine when you are cropping linework.  But in this case I am cropping an imported image.  The image is cropped with the masking region in REVIT but is not cropped when exported to Autocad
Thu, Apr 25, 2013 at 10:00:31 AM | Exporting to Autocad with Masking Regions
and now we hear ".... the rest of the story ..."   Why wait until now to tell us?
You are right.  Imported images are treated differently.  Crop them before you import...
Or ... don't use in a drafting view - use a model view where the view will be cropped.
Thu, Apr 25, 2013 at 10:11:12 AM | WWHub
jwetmore
Quoting WWHub from 2013-04-25 10:00:31
I don't mean to be rude, but I clearly explained that I was using imported images in the first posting of this thread.  I also explained that I do not want to crop the images themselves because then I would have to reimport 100 images.  I am looking for creative ways to deal with this situation.
Thu, Apr 25, 2013 at 10:33:27 AM | Exporting to Autocad with Masking Regions
#13
Not rude - just incorrect..... You may think you mentioned imported images but re-read your first post.  Nothing about imported images into revit.... nothing.  Just ..."We have several images on the sheets."....
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:55 PM
Revit 2010 Masking Regions
Mon, Nov 30, 2009 at 4:42:34 PM
Masking Regions not "masking"
Mon, Dec 14, 2009 at 11:21:22 PM
masking regions
Mon, May 11, 2009 at 4:31:49 PM
Masking Regions
Wed, Nov 14, 2007 at 10:07:16 AM
Page generation time: 0.2316
