Forums >> Revit Structure >> Technical Support >> Upgrading from revit 2012 to 2013
Tue, Apr 23, 2013 at 3:52:28 PM | Upgrading from revit 2012 to 2013
mark7321
I was told by an architect to detach their architectural model before I upgrade my 2012 structural model to 2013. Then the architect said I could reload their 2013 architectural model that they sent me. They said if I left their architectural model attached revit would also try to upgrade their architectural which is over 250 megs and would probably crash the revit program.
I also heard if you upgrade to 2013 you will lose all of the Visibility Graphics settings for very plan and section you previously had created. I have view templates created for all of my plans and a standard one for my sections but is there a setting or method I'm missing so I don't have to apply a view template to very plan and section individually to return it to how it looked prior to the upgrade.
Tue, Apr 23, 2013 at 4:04:40 PM | Upgrading from revit 2012 to 2013
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Is there a question in there somewhere ?
I would upgrade the main project, let it do it's thing (will take a while). It's going to warn you that you should also upgrade the linked file. Then saveas a new file. It is pain stakingly slow especially with linked files.
Then open the linked file on it's own to upgrade that file. Then go back and re-open the main file again.
I haven't come across loosing visibility graphics in this process ? Perhaps others have.
Tue, Apr 23, 2013 at 4:08:03 PM | Upgrading from revit 2012 to 2013
DON'T DETACH....Then you would loose every setting you did with the linked model.  I would just make it unavailable (move it) then mange links after converting and reload from.
You will probably hate 13 and the way it does view templates.  I DO!  - they are locked to the view. We have not upgraded a 2012 to 2013 file, only started new so I don't know what upgrade problems you will have.
GOOD LUCK!  I think we will be skipping 2013 for most of our work.
Tue, Apr 23, 2013 at 4:13:44 PM | Upgrading from revit 2012 to 2013
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Us too. Very few 2013 projects here. It's the bad luck '13'.
Straight to 2014. 2013 was half baked in my opinion. Should never have been released. View Templates got us all excited then kicked us in the ding ding.
Tue, Apr 23, 2013 at 9:34:40 PM | Upgrading from revit 2012 to 2013
mark7321
  One thing I have found with Revit 2013 right out of the box is that masking regions do not work. They are there but don't mask anything. You need to download and install the latest service pack from Autodesk and they will reappear and mask the objects.
  As a structural engineering firm we are required by the architect that hires us to use the revit version compatable with them. I have projects in construction modeled in Revit 2010 and new projects in 2013. It's good to keep a list of which projects are modeled in which release. DO NOT open a model and walk away from your computer if you are not sure what release the model is created in. If you miss the window that says "THIS IS A ONE TIME UPGRADE..... " and it closes before you return to your desk you might not know you accidentally upgraded a model you didn't want to.
Upgrading from revit 2010 to 2012
Thu, Oct 27, 2011 at 7:19:24 AM
When upgrading project files to 2013 unable to make windows families
Fri, Dec 21, 2012 at 2:57:15 PM
"auto" open in Revit 2012, when you have both 2012 and 2013
Sun, Jul 12, 2015 at 4:52:17 PM
Revit 2013 Deleting Hosted Families
Mon, Feb 11, 2013 at 12:05:45 PM
Upgrading Revit 2010 project to Revit 2013
Wed, May 23, 2012 at 1:28:20 PM
Page generation time: 1.5883
