Forums >> Revit Building >> Technical Support >> 2nd Floor View Range
Sat, May 29, 2004 at 11:18:58 AM | 2nd Floor View Range
mbarker
Working on the 2nd floor I can not get the first fllor to show up as an underlay. I have checked everything I can think of. The building pad shows up but no first floor walls are visible. i now it is something simple but I can not sem to put my finger on it.
Sat, May 29, 2004 at 12:32:18 PM | RE: 2nd Floor View Range
skisouth
5 Stars: 3 Votes
If your view range gives you the option of the first floor as underlay, it is probably there if selected. Check your phase setting on the view range. For a quick look, set the phase to Show all. If it doesn't show up then, you need to post more info on what you have tried, view range settings. etc.
Sat, May 29, 2004 at 5:10:04 PM | RE: 2nd Floor View Range
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I've had similar problems underlaying levels with some elements, usually the walls not showing and these have been my walkarounds. I usually change the view properties of the (in you case the 2nd floor) so as the view bottom and depth are set to the bottom of level 1 and then use the linework tool on the elements i wish to see, then reset the view range when i'm finished. Another method is to create a temporary level in approximately the same position as the level below then underlay that level and use the line work tool and once you've finished you can delete the level. I've never really explored why these elements don't display sometimes when underlayed??? Cheers, Chris.
Regards,
Chris.
Visibility of 2nd Floor in REVIT 2011
Sun, Nov 21, 2010 at 8:51:10 PM
Associated Level in View Range
Wed, Nov 12, 2008 at 8:36:23 AM
View range
Fri, Mar 30, 2007 at 11:01:39 AM
view range on uderlay inconsistant with view range of plan view
Thu, Sep 4, 2008 at 3:48:11 PM
Setting the View for Floor Plans
Sun, May 20, 2007 at 8:26:43 PM
Page generation time: 0.7050
