Forums >> Revit Building >> Technical Support >> Revit Worksets won't sync
Mon, Apr 22, 2013 at 4:42:21 PM | Revit Worksets won't sync
benjaminjmather
Our office uses Revit 2013 and is using worksharing for the first time.  One user created the central file of a project.  The other users go to the Revit Open dialog box, find the central file and, with the "Creat New Local" box checked, open the project.  The user that created the central file is able to sync to the central file with no problems, however all the other users are unable to sync, receiving the error message that "Unable to write to ... , it is read only or open by another user."  However the file does not appear to be read only nor open by anyone else.  They are able to "Reload Latest" from the central file, but not sync.  Any thoughts?
Tue, Apr 23, 2013 at 7:08:01 AM | Revit Worksets won't sync
The person that created the file also needs to create his/her own local.  Nobody should be working in the central.  That person also needs to relinquish all.
Tue, Apr 23, 2013 at 8:37:30 AM | Revit Worksets won't sync
benjaminjmather
We've made sure that no one is working in the central file itself.  It even doesn't work when only one person is working on the project (within their own local file).
Tue, Apr 23, 2013 at 9:19:02 AM | Revit Worksets won't sync
This sounds like a network issue.  Are your users allowed to write to this location on the network?
Tue, Apr 23, 2013 at 9:22:07 AM | Revit Worksets won't sync
benjaminjmather
It could be a IT issue, as it looks like only the creator has rights to the central file, and no one else.  We are currently looking into that.
Tue, Apr 23, 2013 at 9:52:14 AM | Revit Worksets won't sync
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I highly suspect the 'other' users do not have 'editable' writes to either the folder or file itself in question. Seen it many times.
cannot enable worksets
Tue, Jan 23, 2018 at 11:00:18 AM
13
Central Model File locations - clouds Revit Arch 2015
Wed, Dec 6, 2017 at 10:10:53 AM
revit MEP 2016 won't open
Tue, Aug 15, 2017 at 9:58:03 PM
Archiving worksets
Thu, Sep 1, 2005 at 2:04:12 PM
Multiple Users Syncing to Same Central File Issue
Fri, Apr 3, 2015 at 1:30:01 PM
Page generation time: 2.5809
