Forums >> Revit Building >> Technical Support >> Parametric Doors - To the Extreme!
Mon, Apr 22, 2013 at 4:12:41 PM | Parametric Doors - To the Extreme!
Kbruno1989
Ladies and Gentleman.
     I am extremely fluent in Revit but am not sure if the following parameter is installed yet... The firm I work at currently work at just completed a Revit project but did it horribly... Basically, I manually filled in a door schedule which as well all know sorta defeats the purpose of Revit being integrated throughout.  I was wondering if it is possible to create a family of a door type that the statistics change based on wall thickness... so if you do a thick 2 hour rated wall, the hour rating in the door schedule changes... opposed to a 1 hour rated wall, that would be thinner.  If you could let me know if there is a thickness wall parameter.  I would appreciate your input on how to go about doing this. THANKS!
Sincerely,
Kevin
Mon, Apr 22, 2013 at 8:08:04 PM | Parametric Doors - To the Extreme!
ronmalit
5 Stars: 3 Votes
hi,
in the family editor, under fire rating, i suggest to use formula IF : if(example = 35 mm, "1hr", "2hr")... and so on
based on your given example and assuming 1hr fire rated door thickness = 35mm
** dont be mad, i dont have much... i am homeless
Mon, Apr 22, 2013 at 8:17:48 PM | Parametric Doors - To the Extreme!
Kbruno1989
Wait... theres a category for Fire Rating?!?! OOO I hate my firm... I KNEW we should of just spent a week on Families and set up this project so it would of gone so much smoother... they have us creating dummy tags and referencing cad sheets -____- THANKS for the help sir!
Mon, Apr 22, 2013 at 8:29:20 PM | Parametric Doors - To the Extreme!
Kbruno1989
Would you be able to list a step by step instructions on how to do this?  I am just alittle unfamiliar with the type parameters / creation of familes... I normally just edit ones I have already!
Fully Parametric door with 45 angle swing
Wed, Mar 26, 2025 at 11:13:10 PM
Creating parametric (array) cabinets
Thu, Feb 14, 2013 at 1:26:47 PM
Problems with parametric double doors
Sat, Oct 29, 2022 at 12:22:53 AM
FAMILY DOORS WITH PARAMETRIC DOOR HANDLE
Wed, Jan 4, 2006 at 11:09:33 AM
Scheduling Pairs of Doors in Revit 2012
Mon, Dec 12, 2011 at 3:16:32 PM
Page generation time: 1.8297
