11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Walkthrough gets 2 major problems when exporting
Im exporting a hidden line level walkthrough for a project. Im tring to pan from the top of the building to an angled shot at the front
1) The exported avi has the entire image chopped off at an angle and appears flat. The missing portion is somehow stuck onto the other side. I have no idea what is causing this or how to fix it. It is honestly one of the weirdest errors I have ever seen
2) At one point the viewport turns 90 degrees when exporting. I can clich through every individual frame in the path and no such error occurs, however when the animation is exported the error is suddenly there
Revit 2013
Edited on: Mon, Apr 22, 2013 at 10:13:46 AM
-Jeff
Intern Architect
Waldon Studio Architects & Planners
Columbia, MD |
Exporting a REVIT animated walk thru can be challenging. It's a massive processing exercise and video card and processing power do come into play.
I'd be very interested if Autodesk 360 may give you better results. It sure does do an awesome job with still renderings.
360 recently started charging so i dont believe that is an option
-Jeff
Intern Architect
Columbia, MD |
Exporting Walkthrough Trouble |
Thu, Apr 17, 2008 at 8:00:50 AM
Help Exporting a Walkthrough |
Tue, May 31, 2011 at 1:39:59 PM
exporting walkthrough to avi |
Wed, Apr 25, 2007 at 5:20:45 AM
Walkthrough Export is very slow |
Fri, Feb 13, 2009 at 2:44:46 PM
Exporting Walkthrough Jpeg - rename? |
Tue, May 1, 2012 at 10:16:06 AM
